Isn't that the phone that phoco was designed round? and you still have probs with it???Quote:
Originally Posted by wizz
Printable View
Read the post again.....I said file transfer & Phoco WORK :)Quote:
Originally Posted by Griff1
It's the new phone plugin that doesn't :(
Wizz
I have a SE W810i and will post my log file tonight after work.
i'll put it another way=Quote:
Phoco was designed round the T610,it should work for you at least,i would of thought.
With that said i was wondering why the interest in the new plugin??
Does every1 have trouble with Phoco under RR?
I got a T610 just to run Phoco because I guessed I wouldn't stand a chance with my SPV C500 SmartphoneQuote:
It runs reasonable under RR, but sometimes doesn't function after hibernation
It's also a bit over the top for me, just call-in, call-out, read phonebook, would do. Which, hopefully, would mean a slimmer, quicker load and smaller overhead.
I am really surprised it won't work in the plugin...especially as someone else in the thread has got a T610 working.
That's basically why I posted & logged, because I would like to know why mine won't work when another will.
Wizz
I know how you feel.
I was chuffed when RRMobile posted about the plugin (especially as he uses the same phone as me) but alas the plugin won't talk to my phone at all.go figure.
Only if you can buy licence for use with RR.Quote:
To be fair...I guess it is very early days for the plugin...so hopefully as time goes by most of us should get what we want. Especially if we give RRMobile maximum support.Quote:
I am lucky...At least I can use Phoco until this plugin is fully developed.
Good point.....Will Phoco be available in the future to use with RR. Possibly not :(Quote:
Originally Posted by MatrixPC
Wizz
Hi, I'm running the plugin stand-alone with a SE T610 using USB cable. In Hyperterm the following AT commands work OK - results supplied.
AT (OK)
ATv1Q0 (OK)
AT+GMI (Sony Ericsson)
AT+CGMM (AAB-1021011-BV)
AT+CBC (+CBC: 1,80)
AT+CSQ (+CSQ: 12,99)
But when running the plugin the log shows only the first AT (OK) works. I saw another logfile for a T610 from another user that had more success.
Hope you keep up this great project.
Is there anything I can do to help get compatibility with Windows Mobile 5 smartphones?
