Page 19 of 103 FirstFirst ... 9101112131415161718192021222324252627282969 ... LastLast
Results 181 to 190 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #181
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by RRMobile
    Thanks Sonic.
    Could you please edit ATCommands.txt and swap the "at+mode=2" and "at+mode=2" so the last line is the Mode=2 where it seems that activate the remote AT control.
    And then send me back the Output result again.
    Thanks in advance
    This is valid for all the Motorola owner. Swap the 2 lines
    Here ya go.
    Attached Files Attached Files
    Live mp3Car Facebook Chat
  2. #182
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    New version available
    New version 0.05 released.
    First post modified!
  3. #183
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Sonicxtacy02
    E815. New version checks manufacturer correctly . Here's my output. I can tell ya right now the reason there's alotta errors is the phone was in mode 0 and not in mode 2 where it needs to be. when commands were sent.
    Try the new 0.05 version and set RRMProfile=Motorola in RRMobile.ini
  4. #184
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Sweet, so this should fix the problems that I was having?
    Peace,
    Rafster
  5. #185
    Jul 2005
    Birmingham,UK
    Great, New version now working fine on T610. Thanks
  6. #186
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    No worky.....
  7. #187
    Constant Bitrate ashgrovered's Avatar
    Jul 2005
    Brisbane Australia
    13 June Version: Not working with my Samsung SGH-E720
    I get the same error as I was getting with the previous version
    It looks like it is sending AT+CPBS=? To the phone and getting an ERROR
    I thought the Command to retrieve the names of the different storages was AT+CPBS?
    Without the “=”
    If I send the command to the phone this is what I get back
    at+cpbs=?
    ERROR
    at+cpbs?
    +CPBS:"SM",5,250
    OK
    Have I not setup something properly
  8. #188
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    HI Ash,you could try commentin out the line Under= " Mobile Termination control and status commands" in ATCommands.txt,that command can be found there in both formats,just put "#" without quotes infront of "AT+CPBS=?".
    I'm not sure it will help but its worth a try.
  9. #189
    Jul 2005
    Brisbane Australia
    Griff1, I dont think ATCommands.txt is used by RRMobile.exe
    I think it is only used with ATSniffer.exe
  10. #190
    Jul 2005
    Brisbane Australia
    I have had a play with hyper terminal and I have found the following works for my Samsung SGH-E720
    If I use the command AT+CPBS=? I get ERROR
    But I do have the following supported Phonebook codes
    SM
    ME
    TA
    I can set each of the phone books with
    AT+CPBS="SM" OK
    Then I can get the Phonebook qty & size returned with
    AT+CPBS? +CPBS:"SM",5,250
    And I can get the data for any entry
    AT+CPBR=5 +CPBR: 5,"*188",129,"Tourist Info",0
    Am I correct in saying that all the command like “AT+CPBS=?” are hard coded in RRMobile.exe.
    And the only user configurable commands are in RRMobile.ini
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
