Page 20 of 103 FirstFirst ... 10111213141516171819202122232425262728293070 ... LastLast
Results 191 to 200 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #191
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by ashgrovered
    I have had a play with hyper terminal and I have found the following works for my Samsung SGH-E720
    If I use the command AT+CPBS=? I get ERROR
    But I do have the following supported Phonebook codes
    SM
    ME
    TA
    I can set each of the phone books with
    AT+CPBS="SM" OK
    Then I can get the Phonebook qty & size returned with
    AT+CPBS? +CPBS:"SM",5,250
    And I can get the data for any entry
    AT+CPBR=5 +CPBR: 5,"*188",129,"Tourist Info",0
    Am I correct in saying that all the command like “AT+CPBS=?” are hard coded in RRMobile.exe.
    And the only user configurable commands are in RRMobile.ini
    Very good analysis !
    I'm preparing the fix. If you give a look to the new ATCommands.txt you will see at the beginning an extensive set of Phonebook related commands. Please run ATSniffer once again and with the result I will prepare the fix
  2. #192
    Constant Bitrate ashgrovered's Avatar
    Jul 2005
    Brisbane Australia
    Thanks but I actually have an issue with the new version of sniffer, it runs and runs and runs and then get a not responding, the old one worked
  3. #193
    Jun 2006
    Milan, Italy
    SM
    ME
    TA
    AT+CPBS="SM" OK
    Try this version. I reduced the commands to access the PB to AT+CPBS="XX" and AT+CPBR=n that seems are the ones widely accepted.
    This version can be used for anyone.
    Just sobstitute the RRMobile.exe in the install dir.
    Have fun!
    Attached Files Attached Files
  4. #194
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hmmm, I finally got mine to connect...
    Now, the only problem I have is getting the phonebook!
    Here is THE log file..
  5. #195
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Rafster
    No worky.....
    Try ATSniffer first and check the correct ComPort
    Edit RRMobile.ini with the found ComPorn number
    Run RRMobile and send me the log
    Ciao!
  6. #196
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by RRMobile
    Ciao!
    Look at the post above you...
    Peace,
    Rafster
  7. #197
    Low Bitrate BioHazard's Avatar
    May 2006
    Luxembourg, EU
    ComPorn
    I'm sure I need this plugin!!!!!
    Project BioHazardous Material || BioHazard . LU
    ████████████████░░░░ CAR
    ████████████░░░░░░░░ LAPTOP
    █████████████░░░░░░░ FRONT-END SKIN
    ██████████████░░░░░░ PERIPHERALS
    ░░░░░░░░░░░░░░░░░░░░ INTEGRATION
  8. #198
    Jun 2006
    Milan, Italy
    What next?
    We are approacing the end of the First satage of the project.
    I hope with this week to solve all the issues discovered by the ones that replyed me.
    This is the "RoadMap" of the project:
    First stage will be to manage the following phone features form the widest range of phone manufacter/model:
    - Get Phone Vendor ID (not very usefull but good to test communication)
    - Get Phone Model ID (like above)
    - Get the list of supported phone phonebook like Internal/SIM/Missed/Recvd...
    - Read the "basic" information of phonebook entries ( name and number)
    Once archived this stage we will have a stable plugin and a "certified" list of phones to continue for the:
    Second Stage:
    - Dial phonebook/manual number
    - Manage the outgoing communication
    - Incoming call event
    - Conference (!!!)
    - Hangup Event
    Third Stage:
    - Audio management
    Fourth Stage:
    - Outlook contact integration
    - Extensive phone phonebook management
    My best guess is that will took 1 or 2 months for any stage
    Ciao
  9. #199
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    New Log for V 0.6 Beta 14
  10. #200
    Jun 2006
    Milan, Italy
    Peace,
    Rafster
    Try the version posted in my last reply to ashgrovered (5 posts ago)
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 05:00 PM
