Page 21 of 103 FirstFirst ... 11121314151617181920212223242526272829303171 ... LastLast
Results 201 to 210 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #201
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by RRMobile
    Try the version posted in my last reply to ashgrovered (5 posts ago)
    Again, a step ahead of you...
    Look at the post above your's...
    peace,
    Rafster
  2. #202
    Constant Bitrate ashgrovered's Avatar
    Jul 2005
    Brisbane Australia
    Thank with the updates .exe you just posted it is working
    Am I correct in saying that ATCommads.txt is only used by the sniffer and not RRmobile.exe
  3. #203
    Jul 2005
    Brisbane Australia
    Has anyone else had the problem with the sniffer locking up and then getting a not responding message from windows
  4. #204
    Jul 2005
    Brisbane Australia
    We are approacing the end of the First satage of the project.
    I hope with this week to solve all the issues discovered by the ones that replyed me.
    This is the "RoadMap" of the project:
    First stage will be to manage the following phone features form the widest range of phone manufacter/model:
    - Get Phone Vendor ID (not very usefull but good to test communication)
    - Get Phone Model ID (like above)
    - Get the list of supported phone phonebook like Internal/SIM/Missed/Recvd...
    - Read the "basic" information of phonebook entries ( name and number)
    Once archived this stage we will have a stable plugin and a "certified" list of phones to continue for the:
    Second Stage:
    - Dial phonebook/manual number
    - Manage the outgoing communication
    - Incoming call event
    - Conference (!!!)
    - Hangup Event
    Third Stage:
    - Audio management
    Fourth Stage:
    - Outlook contact integration
    - Extensive phone phonebook management
    My best guess is that will took 1 or 2 months for any stage
    Ciao
    Is your intention to use the ini file to map your command name to each phone specific command name, or will you be hard coding some command?
    Keep up the great work this is a very worth while project
  5. #205
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Finally was able to get an Output.xls file from my BT port...
    Attached Files Attached Files
  6. #206
    Jul 2005
    Brisbane Australia
    I have attached the output.xls file, but I have used the older version of Sniffer with the current ATCommands.txt also the log file
  7. #207
    FLAC djmickyg's Avatar
    Feb 2004
    Hey VERY NICE work.. !!
    got it working in a matter of minutes..
    thats about 6 months faster than i got phoco to work and its still ****..
    and it isnt using 100% of my resorces loading big images!
    only thing i was having doing wrong was the AT sniffer wasnt connecting my opening my port so i connected the port using the windcom taskbar thingy then sniffed it..
    I'll be following this one for sure
    by the way i have a SE k700i. do i need to post my output file??
  8. #208
    May 2006
    I wish, that the final version has an option to change AT commands and even disable some. Customizeing is the key.
    Thanks.
  9. #209
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by ashgrovered
    Correct!
    The ability to change the AT commands and the sequence is just started with the 0.06 version and is found in RRMobile.ini.
    My plan is to enrich as mutch as possible this configuration to be able to manage as more phone as possible.
  10. #210
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Tippa
    Thanks.
    Give a look to the RRMobile.ini. Is there!!!
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 05:00 PM
