here is a link for motorola at comand set http://www.csparks.com/MotoBackup/MotorolaAT.xml
Printable View
I'm also getting the out of range message but it picks up my battery status etc.
RRMobile, can you please add the possibility to edit the syntax of the AT-Commands in the Ini-file?
a logging function for seeing how the phone reacts would also be nice feature.
can you add this please??
works with with my old Siemens SL45i but i got a crash with SDA Windows Mobile 5...
i too had the same results as everyone else, i'm using a sony-ericsson w810i, on the cingular orange network.
I also have the SDA WM5 (Qtek 8310) but i suspect that it canoot work with the AT style commands sent tru plain Comm port.
Soon or later i will give a look
Hello Vincenzo,
I am very excited to see that there is someone working on what I would personally call lightweight PhoCo alternative.
I have a kind request - would you also eventually consider coding a Meedio plugin with similar basic functionality (pick up/reject phone calls, dial numbers)?
Pretty please :)
First post changed.
I tried it with my Siemens S55 but it won't read the phonebook.
It can read the contacts on the Sim-Card but gives me an error with the contacts saved on my cellphone.
Signal strength , battery, brand and modell are working.
Looks very promising :tard:
Why not but first of all this plugin has to work !!!Quote:
Originally Posted by LagunaICE
Now is an experimental project (see my first post)
Download new version for Log supportQuote:
Originally Posted by t_reich
