Page 41 of 103 FirstFirst ... 31323334353637383940414243444546474849505191 ... LastLast
Results 401 to 410 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #401
    Mar 2006
    Lg Vx8100
    My lg VX8100 works great, but it can't read the phonebook any help?
  2. #402
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by sideone
    I also have the Mot Q. I have returned the phone twice, so i am now using the latest batch of q's.
    <ot>you too? I just had my Q replaced as well. all of a sudden it stopped sending mail. </ot>
  3. #403
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by teo256
    i have tried this with my Nokia 6680. It works great, but i can't read the phonebook...any help?
    Yeah, that's my problem, as was my problem in Phoco....
    Peace,
    Rafster
  4. #404
    Dec 2005
    Quote Originally Posted by tj!2k4
    going on my 4th phone prob next week. I get this issue where i cannot answer calls. When a call comes in, i click answer, but cannot answer the call. I can call them back right after, but it doesnt pick up until i soft reset. I also have times where i cannot place any calls until i soft reset. I have applied all the updates. I have also tried with and without the bt stack. Have you ever had this problem?
    s1
  5. #405
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    s1
    That's actually not a phone issue...
    I used to have VZW about 2 years ago, and that would happen on many phones that I had.....
    It's just part of the MANY negatives of getting CDMA....
    Peace,
    Rafster
  6. #406
    Dec 2005
    Quote Originally Posted by xandTuner
    Have you tried to connect to the virtual com port via Hyperterminal? Can you send AT Commands to the phone with hyperterminal? ( the command "ATZ" There you have to get a STRING "OK", Command: "AT+GMM" Answerstring for example "Nokia 6310" ).
    When you connect to com port, do you get a Signal on you handy, that a connection is working?
    ive done some research, and everyone states that the bt stack for the Serial profile (SPP) has been cripled. I have found one solution that says to set the serial to com1, but i am unsure on how to do this? maybe i need to remotly change the registry entry on the q? i didnt think they were talking about changing to com1 on the pc, but just in case i looked for any settings. In the broadcom bt serial, i was unable to change from com5.
    s1
  7. #407
    Newbie xandTuner's Avatar
    Jul 2006
    Austria
    s1
    I also read about this kind of errorsolution, but i can imagine what this idee resolve? If there is really a bug in the bluetooth driver, try the latest version oft this and hope, that is funzz!
    If you really want to change the com port of your bt. to com 1, go into the "devicmanager" change the Com1 (usually the onboard com) to com(x) an reinstall you bluetooth software, and hope that the software give you the possibility to choose the com1 during the new installation!
  8. #408
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Quattro
    I have a suggestion reagarding the skinning of this app. Well it was actually suggested by LiquidSmoke.
    To make the skining easy so that the skinners don't have to reskin everything you should make the app's skins compatiable with existing Phoco skins. You just need to make your app send the same commands to RR.
    What you think?
    I don't have a clear view of how phoco works becouse i never solved the .NET bug and I didn't see it working (this is one of the reasons why i decide to develop RRMobile).
    About the skin I'm sorry but i need to have a flexible skin and actually I'm making lot of changes!
    The only suggestion is: don't waste to mutch time designing your skin until the plugin is finished!
  9. #409
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Rafster
    Peace,
    Rafster
    Symbyan phone doesn't support AT commands for phonebook reading.
    Suggestion:
    Use your native phone sinchronizzation tool with Outlook and the use the Outlook contact button of RRMobile
  10. #410
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RRMobile
    Have a look at the Phoco commands in RR and try to make yours the same, same with the skin layout. It's pretty easy to work with.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
