Page 43 of 103 FirstFirst ... 33343536373839404142434445464748495051525393 ... LastLast
Results 421 to 430 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #421
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    I tested this with my SonyEricsson k750i today and mainly it worked well. Only a few small bugs, which I'm not sure if anyone has pointed out yet.
    When refreshing (or loading for the first time) the internal phone book, it reaches 144 then slows dramatically. Then it proceeds to continue through my 300 odd contacts very slowly.
    Any entry in the list above 99 wont show in the "contact 1 of 300" text. Ie. it will show 99 300, but then blank for the current phone book entry highlighted for any above 99.
    The entries are not grouped by name, so for example it shows the name "Bob/M", "Bob/H", "Bob/W". Shouldn't it just show "Bob" then when you click to call, it shows each number available for the contact?
    Jarrod - Holden VX S!
  2. #422
    Raw Wave
    Jun 2004
    On the beach
    Quote Originally Posted by dmurray14
    Well, I'm not very knowledgeable, but I'd be happy to test. I know you can set a serial port when you're pairing with the computer. I wonder if it might require writing an app for the phone too?
    Dan
    From what I remember, Phoco uses an app on the phone.
  3. #423
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Jarrod
    The new version will have a partially rewritten phonebook management. Test it in a couple of weeks.
  4. #424
    Low Bitrate jay_tu's Avatar
    Dec 2004
    Towson
    Hey RRMoblie
    I have an lg 8100.... any luck with those yet ??
    what can i do so you would include these also?
    thanks
    04 Corolla
    Modifications:
    Upgrading pc 99%
    Progress
  5. #425
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    With V330, there is one problem. Can't read SIM phone book. Miscall, Received, Dialed and mobile phone book are all fine. Can even notifiy incoming call.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #426
    Jun 2006
    Blackberry anyone...
    Anyone have any luck with a Blackberry yet... I've been doing a ton of homework, and trying to find the strings to get it to talk.
    With Phoco I can Dial - but for the life of me I can't find a hangup/disconnect command that will work. I am doing a lot of the testing from Hyperterm.
    I figured once I got to that point and knew some of the strings, this app would be perfect due to the local phonebook. I am pretty certain from reading that pulling the BB phonebook aint gonna happen, so this would be nice.
    Help would be ever so appreciated? I have an 8700C but would try other commands if you've had luck.
    - ? last question.... This app/process is new to me on the CarPC. How are most people handling the MIC/SOUND without echo. Very curious on that?
    Newbie xandTuner's Avatar
    Jul 2006
    Austria
    Quote Originally Posted by kolemieux
    You said that PhoneCtl works very well. If i remeber phoco has an log file, where the strings get traced in. Maybe you can find some interresting commands in it, good luck!
  8. #428
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Quote Originally Posted by swordfishunter
    but I wonder if the phone is able to support 2 bluetooth streams i.e. 1 to computer other to bt headset.
    Unforutnately I do not think it does. My v525 didn't when I had it. However if it supports the bluetooth 2.0 standard, it should be able to. If it is not bluetooth 2.0, it will most likely not.
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  9. #429
    Jun 2006
    No - actually not at all... Phoco can initiate a dial - hence talk to the phone but that's it. It's like the ATD or ATDT command works but impossible to kill the call/hangup.... Looking for any assist big-time...
    Quote Originally Posted by xandTuner
  10. #430
    Mar 2004
    Toronto, Canada
    have you tried doing a reset with ATZ to see if that will hang it up? What phone is it?
    My XM FAQ
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
