Page 46 of 103 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #451
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Debugging
    Hi
    Just to give you an update of the developing/debugging.
    Thanks to pyros I added the AT+CLCC command that togheter with AT+CLIP give back the "caller identification number".
    Thanks to my brother I'm testing the plugin with his Motorola razrV3 phone and I can say that having more than one mobile is very "healty" for the testing.
    I had to rewrote many part of the core phone communication to be able to manage correctly RING NOCARRIER BUSY... events during the various state of the phone.
    I also discovered the commands for the "phone conference" and for put in hold the conversation (will be added in the future).
    I can work no more than 1 or 2 hours per day and so is taking more time than estimated.
    If no more bugs appear for the WEi will release the new version
    Ciao
  2. #452
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Hi RRMobile,
    Thanks for the hard work. I'm looking forward to giving it a try.
    Just wanted to mention one thing that wasn't available in PhoCo and the RR interface code until the later versions, that is the ability to dial digits after a call is in progress. This is needed for voice mail passwords, calling card dialing, etc. once a call is in progress.
    Just checking. Thanks!
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  3. #453
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Thanks RRM,i'm looking forward to the new version,i think i speak for all when i say i'm glad your continuing with this project even though your time is limited.
  4. #454
  5. #455
    Jun 2006
    DuPont, WA
    Can't receive call
    Just tried to take this program for a spin (build 26). I have a Nokia 6230 on com port 10 and it seems to connect OK... the skin displays the phone model and shows the battery and reception level. When I try to call in, I get the incoming call pop-up, but it immediately gives this error:
    "Error in function: RRM_Refresh. during <not defined>. num:999. desc: (AT) Phone does not respond to commands"
    Any ideas?
    Output of ATSniffer is attached. Thanks!
    Attached Files Attached Files
  6. #456
    Jun 2006
    Milan, Italy
    New Version available at the 1st post
    OK Guys
    The wait is over. I just posted the new version in the 1st page.
    Good luck!
  7. #457
    Jun 2006
    Milan, Italy
    Quote Originally Posted by jeffw View Post
    Any ideas?
    Try the new version and let me know.
  8. #458
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    I've tested it on my k750i using the USB connection and it works perfectly.
    One problem i have is an error coming up when started due to me not using Outlook (Error in function:RRM_PhoneBookGet. during:<not degined>. num:999. desc: Impossible to instance the Outlook ActtiveX object), is there a way i can stop this without bogging down my carpc with unused applications?
    Another is that i can't get it to embed into roadrunner as an application, maybe i'll have more luck by building it into a skin i'm working on.
    Well done buddy, you've done a great job
  9. #459
    Raw Wave
    Jun 2004
    On the beach
    Looking Good RRMobile, just downloaded, working perfectly on incoming calls, just need to workj out the ini settings for outbound calls now
  10. #460
    Nov 2005
    Midlands
    RRM,do i need to enable any commands to scroll right for a contacts other numbers,i can't get to them at the moment.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
