Page 47 of 103 FirstFirst ... 37383940414243444546474849505152535455565797 ... LastLast
Results 461 to 470 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #461
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    How can I read the phonebook of the Siemens S65?
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
  2. #462
    Mar 2006
    RR.INI file
    Is there an issue with the .ini file or do I need to use the one from the original download?
    The manual says to modify settings, but the are not in the file?
    Any thought?
  3. #463
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by 2FastMR2 View Post
    I've tested it on my k750i using the USB connection and it works perfectly.
    One problem i have is an error coming up when started due to me not using Outlook (Error in function:RRM_PhoneBookGet. during:<not degined>. num:999. desc: Impossible to instance the Outlook ActtiveX object), is there a way i can stop this without bogging down my carpc with unused applications?
    Another is that i can't get it to embed into roadrunner as an application, maybe i'll have more luck by building it into a skin i'm working on.
    Well done buddy, you've done a great job
    Yes. Just edit the profile INI file where it configure the Outlook support. Set to "0" the "RRMPBEnabled" parameter
    [PB_OLK]
    RRMPBEnabled=0
    RRMPBName=Outlook Contacts
    RRMPBPhoto=1
  4. #464
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Cheers buddy
  5. #465
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Griff1 View Post
    RRM,do i need to enable any commands to scroll right for a contacts other numbers,i can't get to them at the moment.
    Our Nokia phone, with AT commands only retrieve one number of the internal phonebook entries. To be able to get all the others numbers instead of "AT" commands I have to switch to the Nokia fbus proprietary protocoll.
    This will be done in a later stage...
  6. #466
    Jun 2006
    Milan, Italy
    Quote Originally Posted by piedes72 View Post
    Any thought?
    Use the Standard profile, edit the comm port number parameter and if its works you are the lucky ones that have a standart GSM phone!
  7. #467
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by RRMobile View Post
    Oh,ok,Thanks for the promt reply.
  8. #468
    May 2005
    Is there any settings I need to change? It's not reading my DIALED, RECEIVED and MISSED calls correctly. It seems to be picking up my Internal phone book showing exactly the same number of records and entries.
    I am using the SonyEricsson T610 with Standard profile by the way.
  9. #469
    Newbie SoulCoughy's Avatar
    Mar 2004
    Ohio
    Great work, RRMobile. I'm having a hard time figuring out how to integrate this properly with roadrunner, but it works wonderfully as a standalone app!
  10. #470
    May 2006
    i notised, that even if calling to some numper from memory (SIM) works, why dosent it work when exacly same number is entered manually. Is says calling and afther that conversation 0s and thats that. Is this general error or maybe there is someting wrong with my AT commands? :/
    Using: Siemens GPRS module MC35i with serial cable.
    Attached Files Attached Files
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 05:00 PM
