Page 48 of 103 FirstFirst ... 38394041424344454647484950515253545556575898 ... LastLast
Results 471 to 480 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #471
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by RS200Z View Post
    Is there any settings I need to change? It's not reading my DIALED, RECEIVED and MISSED calls correctly. It seems to be picking up my Internal phone book showing exactly the same number of records and entries.
    I am using the SonyEricsson T610 with Standard profile by the way.
    1) Start RRMobile
    2) Locate the Log dir
    3) erase the daily log
    4) Select the DIALED phonebock
    5) Hit the Refresh button
    6) Stop RRMobile
    7) Give a look to the log file, it will report any errors
    8) If you want you can post it so I can give a look
  2. #472
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Tippa View Post
    i notised, that even if calling to some numper from memory (SIM) works, why dosent it work when exacly same number is entered manually. Is says calling and afther that conversation 0s and thats that. Is this general error or maybe there is someting wrong with my AT commands? :/
    Using: Siemens GPRS module MC35i with serial cable.
    Maybe is a bug. I'll check!
  3. #473
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Download link doesn't work anyone wanna upload it again?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  4. #474
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just tried it and it works fine here :-) just click on the download file on the left hand side just under the title banner thingy.. it doesnt jump out at you on first looking at the page.
    CdR
  5. #475
    Feb 2004
    Manchester
    also am I right in thinking theres.. only 2 screens to skin now ?
    if so nice work.. O and I like your comsend commands.. will come in handy for auto switching screens when a call is received :-)
    going to have a play now
    CdR
  6. #476
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    has anyone made it work with a nokia n70?? it connects to the phone ok but can't even call.. i know in symbian you can not read the phone book but what am i doing wrong in call mang?
  7. #477
    Newbie wolfie_FRV's Avatar
    Apr 2005
    Northampton UK
    Just downloaded and tested and works fine with my Nokia 6230i with no configuration needed. Just changes the com port number and all worked.
    CDr
    Looking forward to your skin for freedom so I can get it fully running in the car.
  8. #478
    Jun 2006
    Milan, Italy
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    Actually is only one because the "Contact" skin and the related functionality is not ready.
  9. #479
    Apr 2006
    Greece
    ok i got it to call from my adress book..end call does not work..aswell as the manual call.. i wonder if it is because of the symbian AT commands.. nice work rrmobile.
  10. #480
    Feb 2004
    Manchester
    ok just having a quick play with this and seeing what can be done / needed for the skin. I have got it reading from the phone no probs at all but I cant seem to get it to make a call either from the list or from the number pad. Also the number pad search doesnt seem to work right, unsure if I'm doing it right, but pressing something like 4 twice should bring up all the contacts for H . I'm also trying to simplify the skin even more.. Since I'm doing it in flash and I'm hoping I will be able to pull your list through into flash the contact / sim / phone / in / out / missed / outlook / refresh will all be in a drop down menu.. unsure on the <- -> buttons as I dont have any double numbers for anyone. I'm also getting a ? in the list where a " " (space) is ment to be. Would it be possible maybe instead of having the <- -> buttons is that if you tap on the contact you need the list then updates showing all the numbers for that contact and then a second press would call that number.. the only reason I'm saying this as it seems theres no way of looking at the number before you call it, so say you want to give out that number to someone, its not possible in its current state (maybe wrong.. lol)
    anyway.. well impressed so for m8 and I've already started on photoshop :-)
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 05:00 PM
