Page 49 of 103 FirstFirst ... 39404142434445464748495051525354555657585999 ... LastLast
Results 481 to 490 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #481
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    looks kinda like mine.. which was made with your graphics of course lol
    Live mp3Car Facebook Chat
  2. #482
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    :-) only problem is that the plugin doesnt support flash at the moment :-( so it will go on hold for a moment I think until I have a bit more time to play with it. I will have to have a play with those files you sent me Sonic.. its just the sooooooooo many skins to do thats putting me off.. lol
    CdR
  3. #483
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by CdRsKuLL View Post
    ok just having a quick play with this and seeing what can be done / needed for the skin. I have got it reading from the phone no probs at all but I cant seem to get it to make a call either from the list or from the number pad. Also the number pad search doesnt seem to work right, unsure if I'm doing it right, but pressing something like 4 twice should bring up all the contacts for H . I'm also trying to simplify the skin even more.. Since I'm doing it in flash and I'm hoping I will be able to pull your list through into flash the contact / sim / phone / in / out / missed / outlook / refresh will all be in a drop down menu.. unsure on the <- -> buttons as I dont have any double numbers for anyone. I'm also getting a ? in the list where a " " (space) is ment to be. Would it be possible maybe instead of having the <- -> buttons is that if you tap on the contact you need the list then updates showing all the numbers for that contact and then a second press would call that number.. the only reason I'm saying this as it seems theres no way of looking at the number before you call it, so say you want to give out that number to someone, its not possible in its current state (maybe wrong.. lol)
    anyway.. well impressed so for m8 and I've already started on photoshop :-)
    Hi CDRSkull
    The Keypad has T9 fuctionality that means you can type any portion of the name you want pressing only once the key related to the letter.
    As an example you are looking for "Bill Clinton" and you only remember the last name (doh!) so if you punch 2-5-4-6 you filter the current phonebook for any name with CLINT as a part of the entry.
    About the dial functionality you ask it will be implemented pressing the contact button (bottom line at the right of the refresh button) in the next version.
    Flash support: Guino left the flash support code in the Plugin souce code but I didn't activated. I will do it as well in the next release (also because I need it to use flash gauges for an ELM OBD2 plugin!)
  4. #484
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    Nice piece of software! It worked instantly with my Nokia 6230i.
    Only the numbad wasnt working correctly. After I hit dial nothing happened.
  5. #485
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    When i try to read the phonebook on my Siemens S65 I get the following errors in the log:
    13:06:11 LOG3 - Output Command: AT+CPBS="ME"<CR>
    13:06:11 LOG3 - Phone communication: <CR><LF>ERROR<CR><LF>
    13:06:11 WARN - Error in function: PhoneCommand. during: <not defined>. num: 999. desc: Command AT+CPBS="ME" not supported by the phone
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
  6. #486
    Jun 2006
    Milan, Italy
    Quote Originally Posted by dbassix View Post
    Run ATSniffer and send me the Output.xls I'll give a look. I have a log of the Siemens MC35i and it works fine
  7. #487
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Goddy View Post
    I found the bug!
    Just replace the RRMobile.exe with this one
    Attached Files Attached Files
  8. #488
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I have a hard time getting it to read the SIM phone book on my moto V330. It can read DC, RC, MC, AD, ME fine but not SM.
    The following is the hyperterminal of some command I tried.
    Code:
    at
    OK
    AT+CPBS=?
    +CPBS: ("ME","SM","MT","ON","DC","MC","RC","AD","FD")
    OK
    AT+CPBS?
    +CPBS: "AD"
    OK
    AT+CPBR=?
    +CPBR: (1-1250),40,16
    OK
    AT+CPBR?
    ERROR
    AT+CPBS="ME"
    OK
    AT+CPBS?
    +CPBS: "ME"
    OK
    AT+CPBR=?
    +CPBR: (1-1000),40,24
    OK
    AT+CPBR=1
    +CPBR: 1,"1714XXXXXXX",129,"Dany Phone Store"
    OK
    AT+CPBS="SM"
    OK
    AT+CPBS?
    +CPBS: "SM"
    OK
    AT+CPBR=?
    +CPBR: (1001-1250),40,16
    OK
    AT+CPBR=1
    ERROR
    AT+MPBR=?
    +MPBR: 1001-1250,40,16,8,0-1,50,(0,2,4,6-7,10-62,255),(0),(0-1),(1-30),(255),25,
    (0-1,255),264,(0),0,0,0,0,0,0,0
    OK
    AT+MPBR?
    ERROR
    AT+MPBR=1
    ERROR
    AT+CPBR?
    ERROR
    AT+CPBS?
    +CPBS: "SM"
    OK
    AT+CPBR=?
    OK
    AT+MPBR=?
    OK
    I wonder how Phoco can get it thru ME instead of SM when all phone # are store in SIM except 2 in phone memory.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  9. #489
    Aug 2006
    Motorola v3
    Hey
    First ofall i rrmobile
    ok got a question does any of you have a working config file for the Motorola v3?
    it all works fine for me Except answering calls .. whenever i pick up a call my Motorola goes to voicemail right away...
    Richard
  10. #490
    Dec 2005
    I appreciate all the work you put in, but sadly the new version doesnt work at all.
    The old 1 worked, but i couldnt dial anything (normal, because you were working on it)
    Now the version that has dialling doesnt work.
    Does anybody have a ini file for a Samsung D500??
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
