Page 54 of 103 FirstFirst ... 4444546474849505152535455565758596061626364 ... LastLast
Results 531 to 540 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #531
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    New Version available at my new Download page
    Hi
    New version is available from my new download page at: http://www.alibri.it/RRMobile/RRMobile.htm
    You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
  2. #532
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    HUZZAH :-) will have a play tonight..
  3. #533
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Thanks RRM.
  4. #534
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just gave this latest a go. Works great, except for two things.
    1. throws up an error because I haven't configured an outlook phonebook. No biggie as I can just hit OK and it skips over it. Is there an ini setting to turn Outlook off?
    2. Makes and receives calls fine, however it won't end a call. When I press the Red handset button I get a beep/bong sound but the call does not end.
    Using a Nokia 6230i
    here is the log file.
    Loaded RRmobile, called phonebook entry Home. Treid pressing red handset button twice.
    Cheers
    Attached Files Attached Files
  5. #535
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Anyone know what could be causing this error.
    I have tried deleting various phonebook enteries, but it still displays the same error.
    Many thanks,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  6. #536
  7. #537
    Sep 2005
    I found you can turn off the contact search by changing either the standard or motorola.ini file.
    Theres a section at the bottom which reads:
    [PB_OLK]
    RRMPBEnabled=0
    RRMPBName=Outlook Contacts
    Obvioulsy change the 0 to 1 if you would like it ENABLED.
    Regards,
    Steve
  8. #538
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Tissy View Post
    [PB_OLK]
    RRMPBEnabled=0
    Regards,
    Steve
    cheers, didn't notice that on first look through. That's solved number 1 for me. Just the hangup I'm hung up on now
  9. #539
    Sep 2005
    Same here mate
  10. #540
    Nov 2005
    Midlands
    Quote Originally Posted by CdRsKuLL View Post
    Scrap that.. did a search..
    I had to change
    RRMCmdDial=ATDT<num>;
    to
    RRMCmdDial=ATD<num>;
    works a treat now :-)
    Try this nokia fans.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
