Page 55 of 103 FirstFirst ... 5454647484950515253545556575859606162636465 ... LastLast
Results 541 to 550 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #541
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Griff1 View Post
    Try this nokia fans.
    Quote Originally Posted by xandTuner View Post
    Hallo RRMobile
    i tested the version 16 Build49 - Nice work you have done there
    There are four mistakes/problems
    1. After Installation to C:\Program Files\Road Runner\RRMobile the program was not installed correctly to this folder
    All Subfolder get installed wrong to C:\Program Files\RRMobile
    Config
    Redist
    Skin
    Sounds
    And all program files are installed correctly to C:\Program Files\Road Runner\RRMobile
    2. The Command “ATH” for hanging Up do not func with my nokia 6230 (for 6310i it works). So I tried to change the command RRMCmdHaungUp from “ATH” to “AT+CHUP”. After trying it with this command there was no change. So I looked into the “ATLog.txt” in I saw that the command is still “ATH”.
    Is there a bug? Is the RRMCmdHaungUp wrong, or is the command hard coded in the source?
    Ahhh I found the error, with the config Entry “RRMCmdHangUp=AT+CHUP” it works, there is the mistake, please correct the ini files you send out in the install shield!
    3. If I close the Bluetooth Connection (on handy) during running RRMobile.exe then the Process gets freez. The last message i saw in programm was that rrmobile wants to read the phonebook. General I think there are some problems if i disconnect / connect bluetooth during ruuning rrMobile
    4. Sometimes if i call a number and hang up the call, the command is not send to handy and the call be allive. Then it helps when i push the call/hangUp Botton once more
    Did you mean to quote this post and not CDR's because I have now solved number 2.
    I am now a happy bunny.
    and I'm going to try a new smiley
  2. #542
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Enforcer View Post
    Just gave this latest a go. Works great, except for two things.
    1. throws up an error because I haven't configured an outlook phonebook. No biggie as I can just hit OK and it skips over it. Is there an ini setting to turn Outlook off?
    2. Makes and receives calls fine, however it won't end a call. When I press the Red handset button I get a beep/bong sound but the call does not end.
    Using a Nokia 6230i
    here is the log file.
    Loaded RRmobile, called phonebook entry Home. Treid pressing red handset button twice.
    Cheers
    For help me better understand what happen for the 2° problem could you please re-run and send again the log?
    The attached version logs more information.
    Attached Files Attached Files
    You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
  3. #543
    Jun 2006
    Milan, Italy
    Quote Originally Posted by Tissy View Post
    Anyone know what could be causing this error.
    I have tried deleting various phonebook enteries, but it still displays the same error.
    Many thanks,
    Steve
    Try the last version posted.
  4. #544
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Yup, that worked great, no errors.
    Many thanks,
    Steve
    PS, When is the SMS options going to be available, this is a really great app.
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  5. #545
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    No,i'm just half asleep and quoted the connect call solution instead of the disconnect solution,sorry bud.
  6. #546
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RRMobile View Post
    The problem was within the config file.
    the config file had
    “RRMCmdHungUp=ATH”
    but when I changed it to
    it works fine.
    this was in the standard one.
  7. #547
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok been playing alittle with the skin.. :-) I keep getting afew errors here and there that I didnt seem to be getting before.. attached is a pic.. and also are the phone icons skinnable.. the little blue ones in the pic below.. O and also.. I'm getting '?' where spaces are ment to be it seems in the names.
    looking good
    CdR
  8. #548
    Feb 2004
    Manchester
    whilst i'm thinking (doesnt happen often)
    would it be possible, when clicking on the name (list) that it updates the phone number pad with its stored number for that name.. doing this then would save having two call buttons.. the numberpad call button would then always call the number stored in its display.. so you would do a search.. ie.. HOM (466) then click on home out of your contacts list.. the number updates on your display and then you click call.. just an idea anyway..
    heres another updated skin.. its getting there now :-)
  9. #549
    Raw Wave
    Jun 2004
    On the beach
    One thing I have noticed is that if I make a call the dialled calls isn't updated until I physically press refresh. Another observation is that if there is a call record without a name against it then it appears as 'no name' is there anyway to make it show the number instead in these instances??
    Other than that looking good so far
  10. #550
    Jul 2004
    Talking VX8100 working
    I did a little more poking around with my config file and am now able to make calls, hang up and receive calls using this plugin.
    My config is attached. I suspect that this will work on most LG CDMA phones (maybe others too).
    I haven't quite figured out how to make my bluetooth audio gateway automatically connect when the call begins and disconnect when the call ends. If I manually turn on the audio gateway the audio is routed through my PC's speakers and Mic (need to make sure that the Mic and not line in is selected as the input source). Does anyone have any ideas on how to have the audio automatically switch? Has this feature been implimented yet? I'm using the WIDCOMM drivers and an $8 zonet usb dongle.
    For those who may be wondering, the VX8100 is able to have both an audio connection and a command (DUN) connection running at the same time.
    -momanz
    EDIT: After A bit more experimentation I don't think connecting and disconnecting the BT audio gateway for each call is such a good idea if your phone can support multiple connections. What may be best is to have RRMobile check on startup (or resuming from hibernation/suspend) if the phone is available and connect the audio gateway at that time. Control over what sound makes it to the speakers can be handled through muting and unmuting of audio sources in the mixer.
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
