cant wait to try this out.. but first i have to get the fone back from being repaired![]()
I have both a i930 and i870 phone. Is anyone out there have this working successfully? If so....please help....
Its getting there, but it still have a few complications when using it as a plugin.. the thing in the rrmobile manual that tells you how to use it within rr is wrong if you want to use it as a plugin.. then line should be...
"PLUGIN;RRMobile;$skinpath$RRMobile\RRmobile.e xe" or where ever you have it.
The problem I've found so far with this is that the 'EXIT' command issued to go back to the calling screen also is used by rrmobile to end its program.. maybe this should be changed to exitrrmobile or quitrrmobile ..
CdR
I try the last RRM but it still have a little hang up problem for me, if there is a incoming call I can't hang up directly,the only way is first answer the call and then I can hang up.
So I checked into the ATLog in that I can't find any ATH command(actually I did), why RRM can't sent hangup command to phone when incall?
ps,The ATH command is working for my phone,sharp 903sh,I test in xp hyperterminal program, ATH command can always hang up a call.
Yeah i've been wondering how it was all gonna tie in,for that very reason.
I suppose the best way for this to work is if its added to the main RR release but i can't see Guino wanting all this additional code.
With that said i'm sure RRM can make the required changes for seamless functionality with RR.
The plugin system was designed for pretty much full integration with RR, with the exit codes altered in RRMobile it should work perfectly with RR, or as far as I know it should.
doesn anyone know if rr mobile works with tiny xp and its cousins?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
