Page 58 of 103 FirstFirst ... 8484950515253545556575859606162636465666768 ... LastLast
Results 571 to 580 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #571
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Hi,vince,this is something for a later date but will RRmobile ever be able to control the modem functions of a mobile phone?
    I only ask because i currently use 2 6310i,one for calls and 1 for modem functions.
  2. #572
    Jul 2004
    at command for HTC pocket pc
    I don't know if it useful but i hope yes because I have
    a qtek 9090 and I wanna use this wonderful software
    http://wiki.xda-developers.com/index...gename=HTC_GSM
    here you can find the at command supported for the HTC PocketPHone
    My is the Blueangel
    thanx for all and good work
    I'm not a programmer but I'm near Milano if you need some help for carputing I'm Here
  3. #573
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    New Version available at my new Download page
    Ver 0.18
    Add: New skin command "quit" to shutdown the plugin
    Fix: RRMobile does not end itself with "exit" command (thanks to CDRSkull)
    This version will help the RoadRunner integration
    You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
  4. #574
    Low Bitrate Cruelkix's Avatar
    May 2006
    Denver, CO
    Quote Originally Posted by RRMobile View Post
    Hi
    Regarding the 1° problem you have to check the correct Dial command your phone support. Usually is ATDT<num>; (where <num> is the number to call).
    other commands are ATD<num>;
    Pay attention to the ";" at the end becouse this specify that is a VOICE call maybe your phone does not support it.
    If you want to make experiments use HyperTerminal plus a few docs you can find in the documentation directory.
    Interesting ... I'll see what I can figure out.
    For the 2° problem actually I don't manage at all the voice. If the BT dongle is "smart" and the phone support 2 concurrent BT ports you can have the voice tru PC and data tru SPP/DUN. Someone say that Motorola manage only one BT connection at the time!
    Well that could potential suck! You are one smart cookie RRmobile. How do you know all this stuff!
    Thanks for the help.
  5. #575
    Newbie DaveST205's Avatar
    Jun 2006
    Manchester
    Ver 0.18
    Hi, I don't see version 0.18 on your website!
  6. #576
    Newbie xandTuner's Avatar
    Jul 2006
    Austria
    Audio gateway
    hello RRMobile
    State: Nokia 6230, newest version of RRMobile.
    I tried to make a call with the command ATD+4366481xxxx8; via Hyperterminal ( or with RRMoblile.exe )
    But I have problems with the audio gateway, it does not activate automatically (for some days i read a post of you, where you wrote that the ";" sign activate the audio gateway mode automatically).
    Interesting is, that the PhoneCtl Tool is possible to activate the audio gatway, but i didn´t find out how.
    i attached the log files of phoneCtl (there it works well) and the log file of rrmobile (there the gateway do not work)
    Have you an idea, why Hyperterminal/RRMobile makes troubles and the PhoneCtl works?
    Attached Files Attached Files
  7. #577
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Enforcer View Post
    The problem was within the config file.
    the config file had
    “RRMCmdHungUp=ATH”
    but when I changed it to
    “RRMCmdHangUp=AT+CHUP”
    it works fine.
    this was in the standard one.
    Now it's stopped working again.
    it won't hang up
    Here's the logs, basically dialled my home number let it ring, then pressed the hang up button. RRmobile reacted as if the call had been closed but the phone carried on as if nothing had happened.
    This is with version 18
  8. #578
    Jul 2006
    Germany
    If someone made RRMobile work properly with Samsung phones, is he/she kind enough to post the config?
    Thanks a bunch!
  9. #579
    Jun 2006
    RR,
    I recently install the RRMobile plugin - but have not been able to get it working...
    What happens is it connects to my LG KG245 via bluetooth SPP (COM 6). RRMobile say opening COM port:6 and my phone responds. But RRMobile continues to say offline and is very unreponsive.
    Attached is my log file
    I have connected to the phone and can execute standard AT commands via Hyperterminal. It seems that from the log file, that RRMobile issues the AT command but does not get a response from the phone (or the AT command doesn't even get to the phone.
  10. #580
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    why all that com port 9 and com port 40 ?
    Lez, more widely known as flez1966
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
