Great stuff!
Anyway to use this plugin with imate JASJAR/Universal/MDA5/XDA5 ?
Regards,
AG
Just tried a few different ports... I have it now set on port 6.. Any ideas on what may be happening..
I read something about version of MSComm - I am running version 6.0.81.69...
Should also mention that I am trying to run RRMobile on my Dell laptop - just for testing prior to setting it up on the CarPC. Just read a post by CdRskull regarding problems with the bluetooth in the Dell laptops.
Might be the cause of the problems.
Great stuff!
Regards,
AG
Ok here is what I did. I am using imate JASJAR WM5.
Connected the phone using IR.
Configured the port.
Ran the ATSniffer.
All commands returned OK.
Ran RRMobile.
Connected to phone.
But no address book/SIM/Battery Indicator
Can't dial a number. In fact no response but phone is still online and connected.
Any idea?
AG
I can get RRMobile to run via my Roadrunner skin, and the "quit" command above closes RRMobile. But Roadrunner is then not visible - I have to use task Manager to kill the process.
What is needed is:
1. RRMobile start automatically when RR starts - just add Phonco path in RR config. But RRMobile should start minimized.
2. When in RRMobile, option to minimize RRMobile and return to Roadrunner skin. That is, leave RRMobile running.
Getting there slowly![]()
Max Perry
Acer laptop Pentium M 735 1.7Ghz, 1.25Gb RAM, 64Gb solid state drive, Windows 7 32-bit
Lilliput 8" LCD 829GL
Garmin Mobile PC GPS
Although I can't get RRMobile to read the phonebook from my Motorola V3x, I have created a phonebook file using Notepad, and RRMobile displays it OK.
But when a phone number is manually dialled (using the number keys) the phonebook disappears as soon as the first number key is pressed, and it can't be brought back.
Max Perry
You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
Well, I'm hooking up my V3 through BT using BTSoleil. After pairing, I can only access 3 service (forgot which 3).
I then do a AT Sniffer and found port 12. Then press the AT Sniffer button for it to download all the data needed for RRMobile to run (dunno what it's called).
I then copy the Motorola.ini file and save it as general.ini while changing the port settings to 12.
Launch RRMobile, it showed an error downloading the phonebook.
I press the 'refresh' button and all is ok. BTW, I'm using the V3's internal memory instead of the SIM card.
Same results?
Hi,
very nice plug-in....but a great program for mobile phone in RR.
Only a question:
Is difficult for U modify it so information gived from ATSniffer are automatic written into a .ini file for the phone tested??
This make the program more simply to everyone....and for me...I'm not so able with AT codes.
Alex
