Page 60 of 103 FirstFirst ... 10505152535455565758596061626364656667686970 ... LastLast
Results 591 to 600 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #591
    Aug 2006
    Quote Originally Posted by Alx0363 View Post
    Hi,
    very nice plug-in....but a great program for mobile phone in RR.
    Only a question:
    Is difficult for U modify it so information gived from ATSniffer are automatic written into a .ini file for the phone tested??
    This make the program more simply to everyone....and for me...I'm not so able with AT codes.
    Alex
    The AT codes will be automatically generated into an excel file, saved at the appropriate place and ready for use if I'm not mistaken.
    Coz I don't have to do anything with the file generated at all. I just need to press the 'AT Sniffer' button for it to start scanning, that all.
  2. #592
    Newbie myth's Avatar
    Sep 2006
    Australia
    Does this plugin support Nokia 3250, I think it's symbian v3 software
    Myth
  3. #593
    Mar 2006
    Italy
    Quote Originally Posted by SentraVIP View Post
    Ok...i see the file...but how does I use it to make the "myphone.ini" file?????
    Alex
  4. #594
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RRMobile View Post
    Could you try the same sequence with this new version. A smaal bug in the log system does not return the correct information in the log files.
    That actually works fine, makes call and hangs up.
    Also the hangup can be seen in both the AT log and the main log.
    cheers
    ps do you still want to see the logs?
  5. #595
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok take that back, it worked the first time. now it won't work again.
    here's the logs. looks like at.log only records the last instance.
    in the main log there are 3 calls, the first worked, the second two didn't, and there seems to be a lot of time missing between logging.
    anf from the ones that don't work, it seems to jump from conversation to lastcall immediately
    ie. PhoneStatus change from: CONVERSATION to: LASTCALL
    Attached Files Attached Files
  6. #596
    Feb 2006
    ...Which he is the just commando in order to add RRMobile? ...I have tried that inserting in the instructions of RRMobile but he does not work. ... please help me...
  7. #597
    Jul 2006
    Jervis Bay, NSW Australia
    Entries in the phonebook utilize the full width of the box in RRMobile.
    But the "selected entry", highlighted in yellow, is truncated and alternates between the start of the name and the end.
    For example:
    PB entry is: Perry, John mobile
    When it is the selected item it displays alternately as
    Perry, Joh
    hn mobile
    Max Perry
    Acer laptop Pentium M 735 1.7Ghz, 1.25Gb RAM, 64Gb solid state drive, Windows 7 32-bit
    Lilliput 8" LCD 829GL
    Garmin Mobile PC GPS
  8. #598
    Mar 2006
    Italy
    Hi RRMobile,
    there are many people like me that don't be able to use AT codes....
    If is possible can U add in Your download site all the RRMP_XXX.ini files that are been tested from users and works fine (where XXX are the model of phone....motorolav3x (mine) for example)...there are over 40 pages of thread, many question about the .ini files of the models of phones and many duplicate.
    Sorry for my bad english....Thanks
    Alex
  9. #599
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Hi RRMobile,
    Alex
    yeah I agree.. someone should do that.. 40 pages is not very encouraging for new users..
  10. #600
    Constant Bitrate teo256's Avatar
    Mar 2006
    Fossombrone (PU), Italy
    Hello, i'm trying to use this plugin with my Nokia 6680 (Symbian OS). RRMobile connects to the phone, can't read phonebooks (i know that with Symbian mobiles is inpossible), can start calls.
    Theese are the problems:
    - Does not turn on the headset
    - Do not hang up calls.
    I've attached Output.xls and Log
    Software [|||||||||-]
    My Own RR Skin [|||-------]
    8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
    RoadRunner - Destinator 6 - Waiting for RRMobile
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
