Page 64 of 103 FirstFirst ... 14545556575859606162636465666768697071727374 ... LastLast
Results 631 to 640 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #631
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    Quote Originally Posted by snapper View Post
    Thanks, hanging up nicely now
    Just to be clear, the ini file needs the following:
    Code:
    RRMCmdHangUp=AT+CHUP
    An no, the audio gateway doesn't work.
    Version: Downloaded the latest zip (RRMobile 0.19.0.63.zip), but the screen still shows ver 18 (build 63), and the .exe. is 18.0063. So guess the zip file is wrong on the download site.
    Don't worry the version is the 0.19 I only forgot to increment the counter. Now is fixed. Last version so is the 0.19 (build 63)
    You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
  2. #632
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    First of all the hang up problem seems to have been solved, it now always hangs up when requested on the three PC's I tried. Me now happy bunny.
    have also managed to get it to work within in RR (well to be called from it anyway)
    Now for some observations
    1. When you receive an incomming call pressing Hangup does not reject/close call. However if you answer and then press hangup it will. (log enclosed includes couple of attempts to hang up when ringing and then an anwser then a hangup)
    2. exit command still seems to disconnect/close RRmobile (or at least the phone gets disconnected)
    3. When using RRmobile as a plugin, it still gets the skin files from the RRmobile directory as opposed to RR's current skin.
    4. Can't seem to access RRMobile's variables (sliders for example) in other screens.
    Attached Files Attached Files
  3. #633
    Dec 2003
    Netherlands
    I saw on the site from centrafuse that it`s has some support for the Nokia N70 (symbian 60 3rd)
    @ Griff1
    RRmobile doesn`t had support for any symbian phone.(or i missed something)
    I thought maybe veetid could give some commands, but youre right cetrafuse is using phoco.
    maybe ask phoco ?
  4. #634
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Tazzios! View Post
    I saw on the site from centrafuse that it`s has some support for the Nokia E70 (symbian 60 3rd)
    What does that have to do with this?
    CF uses Phoco.
  5. #635
    May 2005
    Germany
    Hello,
    couldn´t download rrmobile.
    Ti-ejtsch
  6. #636
  7. #637
    May 2005
    Germany
  8. #638
    Feb 2006
    what is the correct command to add to a menu.skin file in RR to load RRMobile properly from pushing a button in a RR menu??
    I've messed with this for a long time now but can't get it to embed correctly. Seems like RRMobile just wont load inside RR.
    BMW 320 CI - 2000 mod.
    Xenarc/Gain 7" TSV with custom dash frame
    Epia M1000 shuttle pc- 80g hd, dvd, holux gps, linksys wireless
    Opus 120W, Trust BT v2 dongle, Wintv card
    Cadenze 500w rms monoblck,
    Cadenze 4ch 400w rms
    Alpine 12" Type R
  9. #639
    May 2005
    Germany
    @Enforcer
    sorry, but this is only the .exe. I need the full programm/plugin with skin and, and ...
    Ti-ejtsch
  10. #640
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by diskey View Post
    They way I have done it, is by adding
    "RRMOBILE","PLUGIN;RRMobile;c:\program files\road runner\rrmobile\rrmobile.exe" (or whatever the path is to rrmobile)
    to ExecTbl.ini
    and then have a button with "RRMOBILE" as the command.
    Also make sure the skin has a wait.skin.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
