Page 65 of 103 FirstFirst ... 15555657585960616263646566676869707172737475 ... LastLast
Results 641 to 650 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #641
  2. #642
    May 2005
    Germany
    Thanks!
    Ti-
  3. #643
    Feb 2006
    Quote Originally Posted by Enforcer View Post
    They way I have done it, is by adding
    "RRMOBILE","PLUGIN;RRMobile;c:\program files\road runner\rrmobile\rrmobile.exe" (or whatever the path is to rrmobile)
    to ExecTbl.ini
    and then have a button with "RRMOBILE" as the command.
    Also make sure the skin has a wait.skin.
    That did the trick! thanks a lot!
    I'm using Tissy's RRMobile skin, have you made any setup so that when someone calls, and your not inside the mobile skin in simplistique you will get notified ?
    also hang up button when someone is calling isn't working. any clue? it's a nokia 6310.
    BMW 320 CI - 2000 mod.
    Xenarc/Gain 7" TSV with custom dash frame
    Epia M1000 shuttle pc- 80g hd, dvd, holux gps, linksys wireless
    Opus 120W, Trust BT v2 dongle, Wintv card
    Cadenze 500w rms monoblck,
    Cadenze 4ch 400w rms
    Alpine 12" Type R
  4. #644
    May 2005
    Germany
    Hello,
    is it possible to reconnect the phone when lost the connection? I use bluetooth with a Nokia 6230i.
    Ti-ejtsch
  5. #645
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by diskey View Post
    don't think that side is working yet. (I may be wrong though)
    It won't allow you to reject the call, but once you have answered you should be able to hang up. See about 12 posts up for a list of things I have issues with.
  6. #646
    Constant Bitrate RRMobile's Avatar
    Jun 2006
    Milan, Italy
    First of all the hang up problem seems to have been solved, it now always hangs up when requested on the three PC's I tried. Me now happy bunny.
    have also managed to get it to work within in RR (well to be called from it anyway)
    Now for some observations
    1. When you receive an incomming call pressing Hangup does not reject/close call. However if you answer and then press hangup it will. (log enclosed includes couple of attempts to hang up when ringing and then an anwser then a hangup)
    2. exit command still seems to disconnect/close RRmobile (or at least the phone gets disconnected)
    3. When using RRmobile as a plugin, it still gets the skin files from the RRmobile directory as opposed to RR's current skin.
    4. Can't seem to access RRMobile's variables (sliders for example) in other screens.
    Hi Enforcer
    1. I added the functionality to HungUp when the phone id Ringing
    2. Bug!. Now I corrected: when you send the "exit" command I detour it to "hideplugin" command instead. Try it
    3. I added a new parameter in the RRMobile.ini to define a new path
    # SkinPath. Values=any absolute directory (i.e. C:\RRMobile\Skin). Leave empty if you want to use the default "Skin" subdir or fhe installation path
    RRMSkinPath=
    4. Send me an example of the external skin file with the reference of the variable you want to access.
    Attached Files Attached Files
    You can download my Road Runner plugin from: http://www.alibri.it/RRMobile/RRMobile.htm
  7. #647
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RRMobile View Post
    Hi Enforcer
    RRMSkinPath=
    Ok will check tomorrow.
    3. It really should be the current RR skin path setting. Can you not get this from RR or resume.ini ?
  8. #648
    Newbie BEHMER's Avatar
    Jun 2004
    San Francisco
    to ExecTbl.ini
    I have tried this and every other suggestion in here to get RRMobile to run from RR and have had no luck.
    Any help would be greatly appreciated.
    Note: MyRRMobile (V 0.20.0.66) works perfect running stand alone...It just will not embed. I have triple checked all my path names and what not.
    -Custom Widebody 332i-
    -Custom HRE wheels-
    -Focal Audio:-
    Alpine PXA-H701+C701-
    -(2)Focal 33KX-
    -(2)Focal KP165 K3P Kits-
    -(2)Focal FP 1.800 Amps-
    -(2)Focal FP 2.150 Amps-
    -(3)Xenarc 7"TSV Touch LCD’s-
    -PROJECT DETAILS-
  9. #649
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Hi vince,i was wondering if your aware of the current issues regarding the use of this plugin with flash??
    I love this app,as you know i have the same phone as you (lucky for me) and all the currently implimented functions work like a charm.The trouble is that i can't use it as its not sending labels to flash and can't be embedded.
    Quote Originally Posted by CdRsKuLL View Post
    As for RRmobile the main problems with it are that the dont send the labels through to flash and it crashs if it cant find your phone, no reconnect either. I'm sure rrmobile can sort these out and when he does I will do a skin. Can I ask why freefone isnt doing it for you ? I am working hard improving it at the moment.
    thanks
    CdR
    I'd very much appreciate if you could look at these issue's thanks.
    Griff1
  10. #650
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Does anybody know of a make and model of phone which works with this software which allows communication with the PC and a BT Headset.
    I currently have a Motorola V3i, but i can only get a 1-way connection with the PC.
    From what i understand some phones allow BT connections to a PC and a Headset.
    Anything within the Sony Ericson range?
    Many thanks,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
