at the moment, rrmobile can't use the skins in the rr skins folder, it just uses the one in it's own skin folder
Hallo,
thanks, but this is what I have, but it looks like RRMobile stands alone and rr is in the backround. I made a RRMobile.skin in rr\skins but it won´t embedded.
Ti-ejtsch
Aha, this is what I ment!
Ti-ejtsch
I have PhoCo but never really ever used it, bought it mostly to support Zorro, always seemed to a pain to get running no matter what phone I had.
I currently have the Cingular 8125, WM5 phone. PhoCo has a WM5 plugin, think it's a vurtual comport thing, which I d/l when I was trying to get PhoCo to work with my phone. I'm not sure if this is a free program or if its just for registered users, it is a seprate download from PhoCo, you'll probably want to check.
In any case on my 8125 I started the PhoCo adapter. On my desktop I connect to the BT Serial Port (com5). Then ran the AT Sniffer which did whatever it does then locked up. Closed that and ran RRMobile. it seemed to work fine. It was late at night and I didnt' have much time to play with it. But it pulled all my books, Outlook, Calls received, Calls made, Calls missed, etc. It also dialed out but I didn't check receiving calls yet.
I also downloaded the 0.20.0.65 update but when I run RRMobile it shows it as 0.19.0.63. Not sure if thats a problem on my end or what.
I plan on playing with it later this weekend. I just thought this might be of use to fellow WM5 owners.
How to use international symbols in phonebook (eg. russian)?
At present moment RRMobile has it's own skin and works like a plugin. I have a question - Is it possible to leave RRMobile to work on the background with NO SHUT IT DOWN (pressing on EXIT button of RRMobile skin) each time I want to come back to Main Manu. I am under iDrive skin and what command should I use for RRMobile to keep it work and just come back to any another skin ? Is it possible ? Thank you![]()
BMW X5 Carputer Project
Finished: 85%
http://www.mp3car.com/vbulletin/show...lots-pics.html
Not possible at the moment.![]()
Thank you very much! Will wait ...![]()
Finished: 85%
Is anyone else using their phone with a USB cable. I have no problem reading my phonebook, making calls, receiving calls. My only problem is that the sound does not come out through my speakers. I know what I would need to do if I was using bluetooth but I would rather use the USB cable. Please help. I have a SE Z520a. Thanks
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
