Page 68 of 103 FirstFirst ... 18585960616263646566676869707172737475767778 ... LastLast
Results 671 to 680 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #671
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It's time for me to switch phone. The moto V330 is really SUCK with bluetooth. RRMobile can never/rarely get connect with DUN profile. Instead, the phone keep connect with the PC via audio gateway, and it give me problem going to hibernate (can't hibernate because audio gateway is active. WTF????).
    I'm eyeing on the Samsung T519/T629 and soon to be release Nokia 6133 . So far in this thread, both Samsung and Nokia brand phones have problem using RRmobile(and Phoco) in one way or another. I don't really care what phone because my usage is only make and receive calls. I don't do text, chat, bla bla .... My requirement is able to connect to PC bluetooth for RRmobile, audio is a + but I don't care. GRPS/EDGE is prefer. Which of those phones you guys recommend? Tmobile USA don't have that many phone, and I dont' want to spend money to buy fancy phone that 99% of the feature I don't need/use.
    Sorry if this is go off topic, but somewhat RRmobile related .
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #672
    FLAC Mastero's Avatar
    Aug 2001
    India
    Hiya just trying this out ... !
    I read all the pages till this last one..(Did cheat somewhere )
    anyways i am using Nokia 6670 and i have the comport set and the phone is detected here is the Output file.
    It looks there are some error like phonebook .... what changes needs to be done
    Any help is good.
    Thanx
    Mastero
  3. #673
  4. #674
    Aug 2001
    India
    Here u go
    After doing cancel for the phonebook, it says reading contacts from outlook ??
    HELP !
    Mastero
    Attached Files Attached Files
  5. #675
    Aug 2001
    India
    Its almost working ... Could see the battery and signal ..
    Things i cant do ~
    Read contacts
    Keeps saying error ten after starts working.. i have added # to all the AT commands which said error.
    But it says Error in funtion RRMphonebookget.... bla bla bla
    Also phone noise not comming from the comp speakers
    any idea
    cheers
    Mastero
  6. #676
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    Quote Originally Posted by Mastero View Post
    Things i cant do ~
    Read contacts
    any idea
    cheers
    Mastero
    Are you using OUTLOOK Contacts ? If not than disable them in config file.
    Folder Config. Find there the config file you use with your phone and in this file find:
    [PB_OLK]
    RRMPBEnabled=1 <-------------change this to 0
    RRMPBName=Outlook Contacts
    What about "phone noise" --> current version of RRMobile does not support sound transfer trhu bluetooth to your PC.
    BMW X5 Carputer Project
    Finished: 85%
    http://www.mp3car.com/vbulletin/show...lots-pics.html
  7. #677
    Aug 2001
    India
    I am not using Bluetooth ... cable setup
    Got it to work without errors.. had to disable :~
    [PB_SIM]
    RRMPBEnabled=0
    RRMPBName=SIM Card
    RRMPBCmdInit=
    RRMPBCmdOpen=AT+CPBS="SM"
    RRMPBCmdRead=AT+CPBR=<num>
    RRMPBCmdTerm=
    [PB_DIA]
    RRMPBEnabled=0
    RRMPBName=Dialed numbers
    RRMPBCmdInit=
    RRMPBCmdOpen=AT+CPBS="DC"
    RRMPBCmdTerm=
    [PB_REC]
    RRMPBEnabled=0
    RRMPBName=Received calls
    RRMPBCmdInit=
    RRMPBCmdOpen=AT+CPBS="RC"
    RRMPBCmdTerm=
    [PB_MIS]
    RRMPBEnabled=0
    RRMPBName=Missed calls
    RRMPBCmdInit=
    RRMPBCmdOpen=AT+CPBS="MC"
    RRMPBCmdTerm=
    [PB_OLK]
    RRMPBEnabled=0
    RRMPBPhoto=1
    This is what stoped all the errors.
    I am still missing the features like contacts etc .. also i cant disconnect from PC it only dials from the PC.
    Any idea
    Thanx
    Mastero
  8. #678
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    check the hangup/hungup in the standard config file. go back a couple of pages you will see some posts by me about the correct version of that.
    Also there is no ability to get ound through PC yet either with BT or cable.
  9. #679
    Aug 2001
    India
    Well fixed the hangup issue... works nicely now.
    Cheers
    Mastero
  10. #680
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by TimmyM View Post
    I have PhoCo but never really ever used it, bought it mostly to support Zorro, always seemed to a pain to get running no matter what phone I had.
    I currently have the Cingular 8125, WM5 phone. PhoCo has a WM5 plugin, think it's a vurtual comport thing, which I d/l when I was trying to get PhoCo to work with my phone. I'm not sure if this is a free program or if its just for registered users, it is a seprate download from PhoCo, you'll probably want to check.
    In any case on my 8125 I started the PhoCo adapter. On my desktop I connect to the BT Serial Port (com5). Then ran the AT Sniffer which did whatever it does then locked up. Closed that and ran RRMobile. it seemed to work fine. It was late at night and I didnt' have much time to play with it. But it pulled all my books, Outlook, Calls received, Calls made, Calls missed, etc. It also dialed out but I didn't check receiving calls yet.
    I also downloaded the 0.20.0.65 update but when I run RRMobile it shows it as 0.19.0.63. Not sure if thats a problem on my end or what.
    I plan on playing with it later this weekend. I just thought this might be of use to fellow WM5 owners.
    The usage of PhoCoAdapter is restricted to PhoCo only even though it might work with other software.
    Since I've learned that words don't keep some of you from doing it I've built in a security feature in case PhoCo is not the counterpart.
    So be aware that in case of abusing PhoCoAdapter your phone may start doing strange things.
    Skinning to go... VisualDesigner2!
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
