Page 89 of 103 FirstFirst ... 39798081828384858687888990919293949596979899 ... LastLast
Results 881 to 890 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #881
    Dec 2006
    Quote Originally Posted by Enforcer View Post
    My phone is a nokia 6230i and that setting worked for it.
    What you need to do is run ATSniffer and see what commands are available for your phone.
    I know that i need to run the ATSniffer.When i connect the D600 or D500 using serial cable to com1 the sniffer fails to find any AT command supported by the phone, however when i use the same phone connected to USB port it founds many supported AT commands.
    My main problem is to run the RRM over D600\500 with serial data cable and not USB.
  2. #882
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    ATsniffer problems
    Hi,
    I have been trying to use ATsniffer with my verizon vx9800.
    I installed the drivers from the "music pack" sold by verizon. When I plug the phone in, I see 2 ports listed in device manager. Both are listed under the ports section - 1 for CDMA modem and 1 for usb-to-serial.
    When I run ATsniffer (check for comm ports), it will check the comm ports that device manager says are assigned to the CDMA modem (3) and usb-to-serial (4) -- it doesn't find them. It then will lock up.
    Running ATsniffer straight, it just locks up with either comm port 3 or 4.
    What am I screwing up?
    Nasa
  3. #883
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Its worth trying different RTS DTR configurations in ATsniffer,I had a similar problem with my Nokia cos i didn't realise it needed RTS on + DTS off.
  4. #884
    Sep 2006
    Phoenix Az
    Any update on Wm5? i have an T-mobile Dash (Htc Excalibur or HTC S620) and when i try to connect i receive an error " Error in function: RRM_Init. during: <not defined>. num:999. descAT)Phone does not respond to commands
    I tried Phoco and it's working fine (just a few bugs).
    I think it's something related to phoco adapter that it's installed on my phone
    What do you guts think?
  5. #885
    Dec 2006
    Unhappy d500 \ d600 \ d820 serial (rs-232) connection
    Hi All,
    I'm trying to connect using serial cable (rs232) with samsung D500\600\820
    and i just can't make any connection with either one of them on any rate.
    Does anyone got an idea what i'm doing wrong, or they are simply usb only phones?
    Thanks.
  6. #886
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Can anyone help with this problem please.
    As per the instruction to embedd this plugin into RR, i created a PHONE button on my skin and this is the text from the .skin file.
    B02,0,212,270,80,"LOAD;RRMOBILE.skin;RRMobile;C:\P rogram Files\RRMobile\RRMobile.exe;RRMobile","RRMobile"
    However, this does not work at all.
    If I remove (the bit in red)
    Then this loads the plug-in fine.
    However, when i close the phone skin (which is the "exit" call in the RRMobile.skin file), it closes the RR skin also which is obvioulsy behind the RRMobile skin. Then i need to CTRL-ALT-DEL to stop both the exe.
    What am i doing wrong ?? Any help appriciate, as after 4hrs i have just aboout pulled all my hair out !!
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  7. #887
    Sep 2005
    Anyone able to help with the above or if you have it working, please can you post the button code which calls the RRMobile plug-in from RR.
    Many thanks.
  8. #888
    Aug 2006
    PA
    Has anyone had any luck with verizon's vx9800 -- either with bluetooth or usb?
    or, has anyone had luck with verizon phones at all?
    Nasa
  9. #889
    Aug 2006
    PA
    So,
    back again. I was trying to do some research on my vx9800...
    And come across this:
    http://www.yournav.com/forum/index.p...t=&#entry37841
    which states that a user connected his vx9800 to his TomTom. Looking at how it was done, it looks like its some sort of DUN.
    Could anyone explain how this could be done via a computer?
    Nasa
  10. #890
    Desmaano
    Guest
    Question Setting COM-port numbers.
    Hi all people,
    Forgive me for going a bit off-topic but I got a mayby newbie-question about COM-ports. I have an USB-IRport to communicate with my Nokia 7250i but how do i set/find out my COMport nr?
    Searched on my Control Panel but can't find (or looked over it).
    By the way, this plugin is amazing
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
