Page 91 of 103 FirstFirst ... 4181828384858687888990919293949596979899100101 ... LastLast
Results 901 to 910 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #901
  2. #902
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Quote Originally Posted by Nomader View Post
    i believe that audio has nothing to do with rrmobile, phoco or freefone... if one is usingthe correct drivers (widcomm) you can have the audio gateway passed through pc speakers and mic independantly
    tried widcomm drivers and they wouldnt work with my bluetooth
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  3. #903
    Variable Bitrate nemo1's Avatar
    Jun 2006
    I used widcomm drivers and they worked but I had to use an old sony ericsson phone, get it working and then use Razr then it will work. The sony ericsson worked all the time but the Razr works sometimes only.
  4. #904
    Mar 2006
    Montreal
    Nokia F-BUS protocol, open source
    http://www.gnokii.org/
    maybe this thing may be of use for implementation of RRMobile, to support all the rest of the features of Nokia phones
    Tony
  5. #905
    Mar 2006
    Montreal
    Nokia FBus Protocol open source
    Tony
  6. #906
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by nemo1 View Post
    well widcomm drivers are nice but very unstable.. if you have the correct bluetooth dongle you can use them..(they support nearly all of them) recent versions (after 5.1.0.1100) do not support csr bluetooth dongles only broadcom dongles, so if a recent version you find on the net does not work or give you "security...." errors.. then use 5.1.0.1100, it is the last known version to work with csr..(don't ask me what csr is!!!!!, i think it is the chip used).. if it works with your dongle there is probably nothing to keep it from working with your phone...
    your other option if you are not interested in the audio gateway...(listening to calls from pc speaker) then you can just use the windows XP sp2 bluetooth drivers (after sp2 there is support).. they are even better than widcomm as far as connection.
    you can read all about widcomm in
    http://www.gsmhosting.com/
    it is the best source.
  7. #907
    Newbie zuratharamon's Avatar
    Oct 2006
    Athens Greece
    A question, a bit more general though.
    Every time Windows starts, i have to right click on the mobile audio gateway and enable it in order to hear sound from the pc/car speakers.
    Is there a way to be automated?
    Thanx
    Panos
    Zuratharamon @ www.ibizamania.gr
    (Πάνος)(ΜΟΡΣΙΜΟΝ ΗΜΑΡ)
  8. #908
    Apr 2006
    Greece
    Quote Originally Posted by zuratharamon View Post
    Thanx
    Panos
    zuratharamon, I a am interested in finding a solution to this as well ..
    I am sure there is a way..
  9. #909
    Jan 2007
    I got the same issue, also have to start "Audio Gateway" trough the bluetooth icon in taskbar, would be great if there's a way to automate it.
  10. #910
    Newbie R33vit's Avatar
    Mar 2005
    Sydney Australia
    Thanx
    Panos
    Have a look at posts 801 + 806, there is a version that will auto connect headset via BT.
    I have tried it and it works on my W2K PC just fine. It did not work on my XP Pro PC, however I am using a version of XP called 2fast XP which has alot of services turned off, this may be the reason it will not work from my XP PC.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 05:00 PM
