Page 98 of 103 FirstFirst ... 48888990919293949596979899100101102103 LastLast
Results 971 to 980 of 1024
Thread: New Road Runner Mobile Phone Plugin
  1. #971
    Dec 2005
    Sydney
    can't get my n95 to work =(
    get: Error in function: RRM_PhoneBookGet. during: ,not defined.. num: 999. desc: Impossible to instance the Outlook ActtiveX object
  2. #972
    FLAC djmickyg's Avatar
    Feb 2004
    I'm having trouble with my N91 S60v3
    this PIAccess looks interesting..
  3. #973
    Oct 2006
    Smile AT commands for Samsung Blackjack?
    As a newbie, I may be attempting the impossible here, but with all the wealth of info posted on the forum and a little trial and error, am learning a lot about RR and plugins in general. After seaching around the forum for info about compatability of WM5 with this plugin, this is where it stands.
    So far, when I try to connect, the phone screen lights up, the app display says"opening commport x, and after a few secs, the error message "function RRM_Init: phone does not respond to commands." I am connected via bluetooth (Belkins F8T001 using Microsoft BT drivers) and can send/receive files with the computer. When I try to use the ATSniffer and search for available ports, it can open the commports assigned to the phone, but says "no device present" and then locks up. Same for searching for AT commands; the responses show "empty" for each command. It would seem to be a problem between the BT device and RRMobile talking to each other, but not sure about that. I have tried all of the AT initiating commands for the RRMCmdInit line in my Samsung.ini file with no luck. I may be close getting it to work or not at all, but its been interesting and I'm patient!
  4. #974
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I don't know why people continue to post in this thread,RRMobile was never finished and functionality was sketchy at best,time to move on guy's.
    If you want phone software and support then go for Phonecontrol,its wm5 and smartphone compatable and is updated often unlike this,stop flogging this dead horse.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  5. #975
    Newbie VorTechs's Avatar
    Dec 2007
    Gloucester, UK
    I couldn't find Phonecontrol and you didn't paste a link.
    So I've got the source code, found why it whinges like crazy and am fixing things up as I go along to work out what it's doing. I can see it's very dependant on configuration settings that aren't in the public domain, so I'm going to sort that out as an issue so it doesn't go nuts if a configuration isn't available.
    I'll also put the skin together with anything that I do.
    No promises on anything mind you.....
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
  6. #976
    Sep 2007
    Hi All. ive read most of the 65 pages here, but still cant integrate with RR?
    Ive read the inst manual etc. Im trying to integrate with siplistique 2 skin. The original command line was:
    B04,-2,413,369,79,"PHOCO",""
    And my RRMobile folder is currently in:
    C:\Program Files\RRMobile\RRMobile.exe
    So can anybody suggest a new command line that i can use to open rrmobile properly? I can then copy and paste in to the menu.skin folder of simplistique2.
    Or is there anything else that i have to do aswell?
    I know that rrmobile is not currently completed but it works great in standalone mode, and phoco is now closed down, so i have to use rrmobile.
    Any help would be greatly appreciated
  7. #977
    Dec 2007
    Gloucester, UK
    According to the documentation I have, it's something along the lines of:
    B08,10,416,150,110,"LOAD;RRMobile.skin;RRMobile;{ full path to EXE file };RRMobile","RRMobile"
  8. #978
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Does anyone have the source then?
  9. #979
    Feb 2008
    Plugin for Nokia
    Hallo folks
    has someone a Plugin for Nokia
    i receive permanent a error message
    thanks
  10. #980
    May 2006
    I get rrmobile to work standalong but once the calls are made.. i dont hear anything.. through my speakers.. it beeps like it's connecting but I dont hear the call properly...
    I also get an .."error in function: rrm_phonebookget.during <not defined> num 999.desc: impossible to instance the outlook activex object
    i've also tried version 1.4 of phone control and it connects but wont dial and wont grab the phonebook..
    is there any phone software that works yet ?.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
