Results 1 to 5 of 5
Thread: Carweb 2.0 (now Out) (rrplugin)
    Low Bitrate leckan's Avatar
    Jan 2005
    Dalarna,Sweden
    Now you can download Carweb 2.0.
    Work as a RR plugin (Easy to install)
    Http://www.zinknet.se/ENG/
    Carweb 2.0 NOW FOR DOWNLOADING
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    i tried this. Your instructions did not get carweb running in rr. I added the exectbl.ini entry, added the button to my menu skin, and added the carweb folder to rrs folder, moved your skin to my skin folder.. and the button does nothing. Only way i got it to run was to use LOAD;wbrowser.skin;RRCARWEB;C:\Program Files\ROAD RUNNER\CARWEB\carweb.exe;RRCARWEB
    and with that it runs on top of rr instead of in it. What does this do that the built it web browser doesnt? And i have a suggestion. You need the status bar, most of us dial up users with cell phones needa know if the page is loading or just sitting there.
    Live mp3Car Facebook Chat
    Jan 2005
    Dalarna,Sweden
    I have run it in my car for a week without problem you installit exatly same you install rrcdrip. the status bar dont work with the mozilla plugin that i use
    what i know, i found out something.
    put this in your execTBL.ini below the Rrcdrip text.
    /, Set Bellow the Path to the web plugin (if used)
    "CARWEB","PLUGIN;RRCARWEB;C:\Program Files\ROAD RUNNER\CARWEB\carweb.exe"
    "QUIT","SendMsg;RRCARWEB;showplugin||bye"
    "BYE","QUIT"
    go to menu skin and put this code on the button you wanna use,
    B07,348,335,102,75,"CARWEB","CARWEB"
    if you use BMV2 or BAV2 else only change code to CARWEB
    i attach the execTBL.ini , menu.skin
    Attached Files Attached Files
    Jan 2005
    Dalarna,Sweden
    Carweb automatic dail your default connection when you startit.
    an disconnect when you close
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    so far looks good, the install instructions are a little off though. You should design everything so there are no conflicts with any other files or settings in RR. Your "QUIT" command is already present in the ExecTBL.ini file and if you also have CDRIP enabled there will be issues, so you either have to manually combine the comands or you should create a unique command to use for carweb like
    "QUITCARWEB","SendMsg;RRCARWEB;showplugin||bye "
    also you should NOT overwrite any default skin files in RR, your plugin should use 100% of its own files so when you install it, it dosent break any default functions of RR, but yet adds onto.
    The files that get overwritten are
    wbrowser.skin
    So if you install carweb and later decide you dont like it for whatever reason, you now have the issue of restoreing these files and may have to reinstall whatever skin you were using.
    beer replenishment fund
    mp3car live search
  1. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 07:25 AM
  2. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 05:57 PM
  3. USB 1.0 vs USB 2.0? Worth upgrading in my case?
    By SMOKINV8 in forum General Hardware Discussion
    Last Post: 10-17-2005, 10:38 AM
  4. IDE to USB 2.0 converter
    By goosef350 in forum General Hardware Discussion
    Last Post: 08-11-2005, 08:29 PM
  5. 2 questions about 2.0.
    By jgme in forum ME Archive
    Last Post: 09-04-2003, 03:42 PM
