Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 105
Thread: have RR??? Want Traffic cams??? Check here
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    ok i need someone to test this out for me. Its working on my end. Download the .rar. Put the livetraffic folder in C:\program files\road runner\. Open the .ini in the folder and change the skinpath to whatever skin your using (change mc2.5 to the name of your skin folder). After that run the exe. It SHOULD put cam images in your skin folder. Once i've confirmed this works, i'll come up with a solution to allow users to select there own cameras.
    Attached Files Attached Files
    Live mp3Car Facebook Chat
  2. #12
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by Sonicxtacy02 View Post
    I'll test for ya. I'm off for the next 3 days too (not that that has any bearing this... lol)
  3. #13
    Apr 2006
    Washington, DC
    ok, well I had to rename the folder from livetrafficTEST to livetraffic, so the the exe would run, but it only ran for a second, creating only a trafficland.txt file in my livetraffic folder. No pics in my skin folder. Did I miss something?
    edit... the text file is in XML format if that helps...
  4. #14
    Woodbridge, VA
    Blog Entries
    41
    there's a folder inside of the livetrafficTest folder called livetraffic. That folder goes in your rr folder. Then go into that folder and open the ini. should read like this:
    [livetraffic]
    filepath=C:\Program Files\Road Runner\livetraffic
    skinpath=C:\Program Files\Road Runner\skins\MC2.5
    if filepath is something different, change it as it says above. Then change skin path to name of your skin folder. Do not put the "\" after the name.
    The text file should just be a text file, not an .xml. Please confirm its .xml, if it is there's a problem
  5. #15
    Apr 2006
    Washington, DC
    [livetraffic]
    got the ini.. that's edited as should.
    Code:
    [livetraffic]
    skinpath=C:\Program Files\Road Runner\skins\CobraSkin_07
    the text file is trafficland.txt, but if you open the file, the file structure is xml. Attaching first few lines:
    Code:
    <?xml version="1.0" encoding="utf-8"?>
    <!-- City: DC - Baltimore-Washington Area (430 cameras) -->
    <!--  Schema: v100.0.  Report data errors to drew@zitnay.com . -->
    <Region>
            <RegionID>20000</RegionID>
            <Subregions>
    		<Subregion>
    			<SubregionName>DC - Washington (City)</SubregionName>
    			<Cameras>
    				<Camera>
    					<CameraID>200111</CameraID>
    					<CameraName>12th St  NW and Constitution Ave  NW</CameraName>
    					<CameraURL>http://pub.camera.trafficland.com/trafficimage.php?system=pub&amp;webid=200111&amp;pubtoken=5fe8245d2447dca9690ecf6a5f467b29</CameraURL>
    				</Camera>
    And like I said, the program only runs for a second, just long enough to create the text/xml file, then it closes without warning.
  6. #16
    Woodbridge, VA
    Blog Entries
    41
    ok the text file is as it should be.. i just converted the xml downloaded to a .txt so autoit can read it. Now why its not pulling the images is beyond me. Try this .exe (just copy it over your existing one). And make sure you have the latest autoit (they released a new one over the weekend).
  7. #17
    Woodbridge, VA
    Blog Entries
    41
    while ur at it tell me what size your .txt file is. Should be 116kb
  8. #18
    Apr 2006
    Washington, DC
    Sweet a new version of AutoIT and an update to SCITE. lol anyways... sorry dude, same result. runs for a sec, creates the txt file, then closes out.
  9. #19
    Apr 2006
    Washington, DC
    yep, 116kb
  10. #20
    Woodbridge, VA
    Blog Entries
    41
    well damn! Ok check to make sure you only have one livetraffic folder. Make sure its C:\program files\road runner\livetraffic and not C:\program files\road runner\livetraffic\livetraffic. If this is the case then please try this customized version of the .exe. Its my first version without the variables for file and skin path. It will put the .txt file in C:\program files\road runner\livetraffic\livetraffic and read it from there. Then it'll pull the images and place them in your CobraSkin_07 folder. Both versions are working on all of my computers.
  1. RR "-4.3" video freeze!
    By RaVEWHQ in forum RR Bug Tracker
    Last Post: 04-24-2006, 11:26 PM
  2. General question about the RR program logic
    By DaveB in forum Road Runner
    Last Post: 03-19-2006, 11:26 PM
  3. RR vs Frodo
    By tbird2340 in forum Road Runner
    Last Post: 03-07-2006, 05:25 AM
  4. Traffic info for Maryland/Wash. DC for RR
    By Civic03 in forum Road Runner
    Last Post: 02-03-2006, 11:48 AM
  5. Dialup in RR without Phoco?
    By kbreeden in forum Road Runner
    Last Post: 12-12-2005, 08:04 PM
