Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 105
Thread: have RR??? Want Traffic cams??? Check here
  1. #21
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by Sonicxtacy02 View Post
    well damn! Ok check to make sure you only have one livetraffic folder. Make sure its C:\program files\road runner\livetraffic and not C:\program files\road runner\livetraffic\livetraffic. If this is the case then please try this customized version of the .exe. Its my first version without the variables for file and skin path. It will put the .txt file in C:\program files\road runner\livetraffic\livetraffic and read it from there. Then it'll pull the images and place them in your CobraSkin_07 folder. Both versions are working on all of my computers.
    ok, not sure why this worked, but it did. I have 6 sweet cam pics in my cobraskin_07 folder
  2. #22
    Apr 2006
    Washington, DC
    oh crap... figured it out dude..
    Ok, the first rar file you had for download, had the following file structure.
    \livetrafficTEST\livetrafficTEST.exe
    \livetrafficTEST\livetraffic\livetraffic.ini
    I of course renamed the livetrafficTEST folder to livetraffic, since that was the naming convention in the INI file. What worked, was the following:
    \livetraffic\livetrafficTEST.exe (with or without the TEST in the exe filename worked)
    The first file now places the pics in my CobraSkin_07 folder... lol now we just need to configure the particular cams ;-)
  3. #23
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    great news. I'll get to workin on that but its gonna take some time considering there's 436 possible choices lol
    Live mp3Car Facebook Chat
  4. #24
    Apr 2006
    Washington, DC
    lol completely understandable. thanks much for this. I've sooooo been wanting this. :-) Let me know if you need any more testing. Hit me up on any of the IM services if need be. Thanks again.
  5. #25
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Wow this looks neat
    I live between Baltimore and Washington
    Ellicott city and Columbia area
    2001 S10 ZR2
    Chucks Skin - to old
  6. #26
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Chuck View Post
    Wow this looks neat
    if you see a cam on the trafficland map for ya it can work with my program . I should be thanking you, my loadimg concepts came from your radar skins.
  7. #27
    Aug 2006
    what exactly do i need to do with autoit, to get this working,
    i follow the directions in this forum, i have MC2.0 as my skin, where do i access this in the skin?
  8. #28
    Apr 2006
    Washington, DC
    I have it running/intergrated in my latest skin. As far as I know, you don't need to do anything with AutoIt except maybe have it installed.
    Here is my button code to run the program and then load the images into the livetraffic/traffic cam skin.
    Code:
    B,580,252,203,100,"RUNW;C:\PROGRAM FILES\ROAD RUNNER\LIVETRAFFIC\LIVETRAFFIC.EXE||Load;traffic.skin||LOADIMG;20;78;250;200;glebe.jpg;OUT||LOADIMG;275;78;250;200;lynn.jpg;OUT||LOADIMG;530;78;250;200;parkway.jpg;OUT||LOADIMG;20;303;250;200;canal.jpg;OUT||LOADIMG;275;303;250;200;wash.jpg;OUT||LOADIMG;530;303;250;200;edsall.jpg;OUT",
    I use "RUNW" so it runs the livetraffic program, road runner waits till it has downloaded the new images and then loads the traffic.skin.
    Also, I remember a problem with the folder setup. Ensure the "livetraffic" folder is in your Road Runner folder, and inside your livetraffic folder, you have the following files:
    livetraffic.exe
    livetraffic.ini (possibly need to copy and edit from a subfolder)
    trafficland.txt
    the livetraffic.ini file should have the filepath for the program and the skinpath which should point to the current skin your using and trying to load the traffic cam images. i.e.:
    Code:
    [livetraffic]
    filepath=C:\Program Files\Road Runner\livetraffic
    skinpath=C:\Program Files\Road Runner\skins\COBRA_08\SKIN\
    I've attached my livetraffic folder. NOTE that the traffic cams aren't yet configurable, Sonic is still adding that in as far as I know...
    Attached Files Attached Files
  9. #29
    Aug 2006
    i downloaded your skin and i got it to open but its not a live feed,
    how would i use it in another skin?
  10. #30
    Apr 2006
    Washington, DC
    Quote Originally Posted by 1stclasso View Post
    what do you mean live feed? my skin is setup to run the program, download the new images and display those new images. If it's not working correctly, ensure you have the file and skin locations set right in the \livetraffic\livetraffic.ini file. The traffic cams ARE NOT live, you only get updated screen shots. The more often the program is run, and thereby downloading the latest pics from the website, the more updated pics you get. The skin will pull the images from the same folder that it's in.
    To use it in another skin, just copy the TRAFFIC button code from the main menu and create your own button in your skin with the same code, and copy the contents of the traffic.skin to your skin. i.e. the label code, etc...
  1. RR "-4.3" video freeze!
    By RaVEWHQ in forum RR Bug Tracker
    Last Post: 04-25-2006, 12:26 AM
  2. General question about the RR program logic
    By DaveB in forum Road Runner
    Last Post: 03-20-2006, 12:26 AM
  3. RR vs Frodo
    By tbird2340 in forum Road Runner
    Last Post: 03-07-2006, 06:25 AM
  4. Traffic info for Maryland/Wash. DC for RR
    By Civic03 in forum Road Runner
    Last Post: 02-03-2006, 12:48 PM
  5. Dialup in RR without Phoco?
    By kbreeden in forum Road Runner
    Last Post: 12-12-2005, 09:04 PM
