Results 11 to 20 of 24
Thread: Plugin for bookmarks, rating and pois - Beta
  1. #11
    Mar 2006
    if you press the "save" button, you send the command with "fscommand("poisave;45.332;54.753;Radar20060912;Ra dar")". This is for flash and i dont know how to do it in non-flash skins.
    It's clear that it can only calculate the distance, when you send the current position to the plugin with "fscommand("poiposi;45.332;54.753")"
    About the label: To show the name of the nearest poi the label must be called: "poiname1", the distance is called "poidis1" and so on.
    i include the main screen of my skin, maybe this helps
    Attached Files Attached Files
  2. #12
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by ReflexNPG View Post
    please note that i posted the source, so you can do it "correctly"
    I dont use iguidance, so i will not implement this.
    things to be implemented (until now):
    - tripmeter, fuel consumption, etc
    - simple rss reader
    - more id3v2 tags including lyrics and albumart
    - extended albumart (show all pics in the folder as slideshow)
    its not a feature that needs to be put in your plugin its a feature being added to rr that ur program could use mapping lat and lon coordinates.
    Live mp3Car Facebook Chat
  3. #13
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Ok, I think I got it!!!! I was trying to figgure out the button code, from a standard Road Runner skin point of view, NOT from a Flash standpoint! Thats why it did not make sence to me.
    That ends it right there, and I will not be able to take advantage of your plugin I do not use flash based skins, so I will have to find another way to go about doing this. Sorry for all the confusion.
    My Fiero Build Thread
  4. #14
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    so i want to clarify this, does this plugin only work if you are using FLASH SKINS ?
    So far i cant get anything to work. Im most interested in the bookmark feature. Ive tried a few of the label codes but non of them show anything.
    beer replenishment fund
    mp3car live search
  5. #15
    Woodbridge, VA
    Blog Entries
    55
    there's nothing that flash can do from a command standpoint that a non-flash skin can't do. In fact, alot of rr commands cannot be run directly thru flash. The way to get around this is to use exectbl.ini.
    Everyone here is confused on how pressing the POISAVE button takes the LAT and LON coordinates and enters them into the button command so rr can process it.
  6. #16
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    And I honestly thought it was just me. Sonic and LS, you guys made me feel a little better
    I have been wanting something like what this is supposed to do for quite a long time now. (The POI aspect of it). Could be used when approaching speed camera's, (I use IG not Destinator) rest stops on long interstates, known speed trap area's, Toll booths ect ect....
  7. #17
    Mar 2006
    Quote Originally Posted by liquid_smoke View Post
    i never tried it with other skins...
    sorry, that it is not working 4 u.
    some remarks:
    - there is no label which is related to the bookmark feature (you can save and load a bookmark, thats all)
    - all labels require to do some action before they will output something (for pois u must tell the plugin the position, for fileinfo the filename)
    I will provide a better documentation 4 the release version...
  8. #18
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Really? So let me explain 4 everyone how difficult it is:
    you have rr labels for latitude and longitude. Just define them for the skin and automagically u can use them.
    Now comes final part - send the command to rr (here is an example):
    fscommand("poisave;" + _root.GPSLAT + ";" + _root.GPSLON + ";" + _root.POISAVE + ";" + _root.Category);
    -poisave is the name of the poi
    -category is the category string
    Thats all....hope it helps
  9. #19
    Woodbridge, VA
    Blog Entries
    55
    now THAT explains it ! that command could also be run on a non flash skin. All you would need to do is create variables for GPSLAT GPSLON and the like and the information would be loaded into rr at the time the button is pressed
  10. #20
    Aug 2003
    Chicago
    some remarks:
    so how would you pass the information to the label? I kind of would expect the lablel to go out and find the information and bring it back to me for example in a lablel i just put "-id3artist" as the code, is there more i need to do. I also tried "id3artist" not sure about the dashes.
    I never got to actually try the bookmark feature as i couldn't get any of the labels to work i knew i would have problems after that.
    Some other questions, are the dashes "-" apart of your commands, i notice you use them all over, like -id3artist. Just curious cuz nothing else in RR uses a dash or underscore.
    mp3car live search
