Are you planning to make RS2 work with the default BMV2 skin? I'm trying to get it to work.
Ok I edited the skin of the default Radio Shark 2 skin to make it more touchscreen friendly. It's not perfect but I wanted to go ahead and release what I've done, so others may take advantage of it.
I will be releasing a better looking, truly fresh from the ground up skin, as this one is just a scaled up version of the default skin, so stay tuned.
.1 Beta Release (Dowload HERE - @ CarPCNet)
Screenshot:
Extract this archive to the root folder of your Radio Shark program folder.
It will overwrite the RSOptions.ini file, so back that up first if you want to keep your default settings.
For the modified skin to work, the RSOptions.ini file must be edited. The second to last line will read:
FullSkinFile=Skins\Standard\Skin_Standard.xml
change that to:
FullSkinFile=Skins\RR_Skin\Skin_Standard.xml
If you just extract the modified skin to the root folder, you will overwrite that file and the program will use the new modified skin.
I haven't been able to test ALL of the features, so please let me know if you encounter any errors or misplacement for display items.
To create your own skin, edit the PNG graphics in the \SKINS\RR_Skin\ folder. Keep the file names the same.
If you want to make huge changes to the skin (like placement of display items, buttons, etc), you'll have to edit the XML file. Make a backup if you do that. Not all items are relative to the main skin borders, but other items in the skin itself.
If you have any questions, post them in this thread:
The W3bMa5t3r
I'm afraid not. I know nothing about the plugin created nor do I have any clue on how to interface RS2 with RR... I simply modded the RS2 skin to be more touchscreen friendly for embedding. Hopefully someone else will be able to take that on![]()
if you can point me in the right direction to start off as what i need to do, i would be happy to do this. How would i make the default bmv radio skin work with rs2?
