Results 1 to 2 of 2
Thread: JoyVol Plugin
    Constant Bitrate Beezer's Avatar
    Oct 2006
    JoyVol Plugin
    This plugin allows volume control using a variable resistor or potentiometer connected to the PC's Joystick port. Hardware wiring is very simple & you can find out further details in this thread Soarer Volume Control Your potentiometer should be wired to the x-axis and calibrated in windows.
    It also supports a single button wired to button 1. Behavior is configurable in the config file for Mute, Pause, Stop.
    All configurables as follows:-
    [Joystick]
    Max= 62556 <-- use the calibrate button to generate this
    Min= 0 <-- use the calibrate button to generate this
    pressType=Stop <-- valid values - Mute, Pause and Stop. Default Mute
    mixerLine=Master <-- any valid RR mixer line. Defaults to Master
    pollRate=200 <-- the rate at which the joystick is polled in milliseconds. Defaults to 50.
    You can find the software here, and you can find the source code here.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can this be used to control anything besides volume? ideally to give a value based on a pot's position?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
