Page 10 of 25 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 248
Thread: siLABS RADIO PLUGIN
  1. #91
    Dec 2005
    Sydney
    i had the same problem when trying the regular skin. The radio just always seems to be on. Does anyone know how to fix that?
  2. #92
    Dec 2005
    Sydney
    Quote Originally Posted by Naesstrom View Post
    well I'm not the best skinner out there but I', trying to make it work with the IPhone skin and it's all the same way!
    first go and get the RR skineditor, open up your simplistique skin and choose the radio screen from the list of skin files, then open up the radio skin that comes with this plugin and just copy everything that u want over to the new one!
    just play around some with the skineditor and u'll get a hang of how it works!
    Thanks for the tip!
  3. #93
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by SmoL View Post
    Anyone, trying to make a new skin and this is kind of a problem... sure the radio is fun to listen to but I really like my mp3's to...
    Swedish site for CarPC's
    http://www.bilpc.info
  4. #94
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    OK another silabs issue, I dont know if it affects it when used through a skin or with this plugin, but it probably does..., I only use the official silabs app for the moment, as I am still looking for a skin I like, but the problem is this.......
    My ac97 onboard-craposound-alc655 wont go into 4 channel mode via waveout.dll, only via directsound.dll (ds.dll?)
    This is ok for winamp as you can tell it to use directsound, but the silabs app has no setting for this, so with the silabs app I only get sound on the front 2 channels, not the front and rear.
    Anyone any idea how I can fix this? (in software)
    Lez, more widely known as flez1966
  5. #95
    Mar 2005
    Sweden/Vaxjo
    I just have 2 small questions...
    first of all I have a small memory of reading somewhere that silabs is having trouble with the RDS function, if not I must have set it up wrong somehow since it refuses to search for better reception...
    The next one might have been answered somewhere in the thread earlier but I couldn't find it, the Traffic function... does that mute whatever else I have playing and unmute the radio or does it only switch between radio stations while I'm in radio mode?
    oh, and still no one that have a clue how to get it to shut up when not using the skin that came with it...
  6. #96
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    I use this to exit the radio skin: B09,698,531,102,69,"radio_mute||EXIT||RESUME","Exi t"
    It will start playing MP3 and mute the radio.
    I use this to go into the radio skin:
    "ICERADIO","LOAD;ICE_RADIO.skin||PAUSE||radio_unmu te"
    This will pause whatever it was playing and unmute the radio.
    For the other questions.
    In the plugin the traffic function will only 'listen' to the current station and will pause mp3/video/dvd when a traffic announcement is being broadcasted while unmuting the radio. It will after the broadcast mute the radio and resume whatever it was playing.
    However it does not currently use the EON function to switch to another station when a traffic announcement is being broadcasted.
    For the AF function... Currently it only does search for a stronger station when clicking the AF indicator. The SiLabs is not capable of a silent signal check of other stations so it is just switching the alternate frequencies it had received from RDS.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  7. #97
    Dec 2005
    Sydney
    does that mean that when you first open rr it will be unmuted?
  8. #98
    Apr 2005
    The Netherlands
    No, when the plugin is loaded it mutes the radio by default.
  9. #99
    Newbie R33vit's Avatar
    Mar 2005
    Sydney Australia
    Is it at all possible to get this to work in Win2K?
  10. #100
    May 2006
    Tmc!
    Hello,
    Will you add TMC encoding?
    Regards /Jörgen
  1. radioSHARK Plugin for RoadRunner
    By Evolution VIII in forum RR Plugins
    Last Post: 09-30-2007, 06:55 PM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  3. Replies: 17
    Last Post: 10-29-2006, 11:55 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Sirius Radio Plugin...
    By ThermoDust in forum Centrafuse
    Last Post: 08-27-2005, 09:20 PM
