@307SW_NLD
I have problems with the RADIO_BAND function
My skin file button line for it, looks like this:
B11,73,254,71,87,"RADIO_BAND",
But it does not work at all.
What have I done wrong?
Best regards
Henrik
My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
Hardware: None at the moment
Software: None at the moment
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 0 % DONE
Here is the E36 skin for the siLABS RADIO PLUGIN
Enjoy!
Henrik
And the PSD's for those who want to edit...
Henrik
So, no picture of that audio cable soldering... I'm about to solder my antenna to the stick and was planing on doing that mod to when I'm at it!
Swedish site for CarPC's
http://www.bilpc.info
The audio is brought out through the usb connector, why do want to put it on a cable?
{edit}
Silly me I can see why, to use HW to fix a software issue, silly me..........
Did anyone notice the silabs application has no problem giving silence after quitting, and needs no hardware fix....
Why cant you just do this every time it exits?
And enable it when needed ?
It seems so much simpler than a HW cludge.
Lez, more widely known as flez1966
Quote from post found 153 a few pages back or use thislink
[edit]Finally got rid of the annoying static...
Steps to solve (only for the brave at heart)
1. Disable the "USB Audio Device" in the Sound, Video and Game Controllers Section of the Device Manager in windows
2. Check that there is no static anymore (but there is no radio sound at all since we have disable the sound from the radio comming throught the USB device)
3. Solder the wires of an old head phone with a 3,5 mm jack to pin 3 (left channel) of the amplifier chip (this is the middle chip on the SiLabs radio) and pin 5 (right channel). Solder the ground of your hard phone cable at some plave that is grounded in the USB device (I mesefl used the hole next to the antenna wire
4. Connect to 3,5mm jack to your line-in connector on your soundcard/main board.
This will give you crystal clear sound when using the radio and complete silence when not using the radio.
Was making the post while you edited yours :P
well, didn't think someone even was thinking of making a "patch" or something so then the only way was to fix it by doing some soldering!
