Originally Posted by
LTi
Thx Pete
I am looking forward the latest source.
By the way could you send me just the USBRadio.h of the latest DLL?
And where can i download the latest DLL?
And c u at digital-car.
Regards
Code:
// The following ifdef block is the standard way of creating macros which make exporting
// from a DLL simpler. All files within this DLL are compiled with the USBRADIO_EXPORTS
// symbol defined on the command line. this symbol should not be defined on any project
// that uses this DLL. This way any other project whose source files include this file see
// USBRADIO_API functions as being imported from a DLL, wheras this DLL sees symbols
// defined with this macro as being exported.
#include "FMRadioDevice.h"
//#include "oleauto.h"
#ifdef USBRADIO_EXPORTS
#define USBRADIO_API __declspec(dllexport)
#else
#define USBRADIO_API __declspec(dllimport)
#endif
//Tested
USBRADIO_API bool __stdcall HWInit();
USBRADIO_API bool __stdcall HWInitEx(bool enableSound);
USBRADIO_API bool __stdcall HWDeInit();
USBRADIO_API bool __stdcall FMTune (long frequency);
USBRADIO_API unsigned int __stdcall GetSignal();
USBRADIO_API long __stdcall GetCurrStation();
USBRADIO_API long __stdcall SeekStation(bool SeekUp);
USBRADIO_API bool __stdcall IsStereo();
USBRADIO_API const char* __stdcall GetRDS();
USBRADIO_API long __stdcall ScanStation (bool directionUpDown, long startFrequency);
USBRADIO_API bool __stdcall FMTuneUp ();
USBRADIO_API bool __stdcall FMTuneDown ();
USBRADIO_API char* __stdcall GetModuleName();
USBRADIO_API unsigned long __stdcall GetModuleInfo();
USBRADIO_API void __stdcall TuneFreq (long frequency);
USBRADIO_API void __stdcall SetMute(bool mute);
USBRADIO_API unsigned int __stdcall GetVolume();
// Doesn't support different volume levels per side, ignores right side
USBRADIO_API void __stdcall SetVolume(unsigned int left, unsigned int right);
USBRADIO_API void __stdcall VolumeUpDown(int step);
//VB calls!
USBRADIO_API bool __stdcall VB_GetModuleName (char szReturnModuleName[256], short *iSize);
USBRADIO_API bool __stdcall VB_GetFrequency (double frequency);
USBRADIO_API bool __stdcall VB_GetRDSText (char szRetRDS[256], short *iRetSize);
USBRADIO_API bool __stdcall VB_GetRDSPS (char szRetRDS[8], short *iRetSize);
USBRADIO_API bool __stdcall VB_GetRDSPIRegion (char szRetRDS[8], short *iRetSize);
USBRADIO_API bool __stdcall VB_GetRDSPICountry (char szRetRDS[8], short *iRetSize);
USBRADIO_API bool __stdcall VB_GetRDSPI (int *rdsPI);
USBRADIO_API bool __stdcall VB_GetRDSPTY (short *rdsPTY);
USBRADIO_API bool __stdcall VB_GetRDSTA (bool *rdsTA);
USBRADIO_API bool __stdcall VB_GetRDSTP (bool *rdsTP);
USBRADIO_API bool __stdcall VB_GetRDSMS (bool *rdsMS);
USBRADIO_API bool __stdcall VB_GetRDSEON (bool *rdsMS);
USBRADIO_API bool __stdcall VB_GetRadioRegisters (char szRetBuf[256], short *iRetBufSize);
USBRADIO_API bool __stdcall VB_GetAFList (float* ary, int* arysize);
USBRADIO_API bool __stdcall VB_GetRDSRegisters (char szRetBuf[256], short *iRetBufSize);
USBRADIO_API bool __stdcall RegisterTAStart (char windowName[256], short dwData, char lpData[256]);
USBRADIO_API bool __stdcall RegisterTAStop (char windowName[256], short dwData, char lpData[256]);
USBRADIO_API bool __stdcall RegisterRadioText (char windowName[256], short dwData, char lpData[256]);
USBRADIO_API bool __stdcall TAEnable(bool enableTA);
USBRADIO_API bool __stdcall TAActive();
USBRADIO_API bool __stdcall SetExFlags(long Flags);
USBRADIO_API bool __stdcall TAEndAlert();
USBRADIO_API bool __stdcall TATestSendTA(bool SendStart);
Forgot about the last 2 functions, TAEndAlert is used to cancel the current TA (forces the radio to tune back to the station it was on prior to the TA) without disabling TA. I added TATestSendTA to allow me to debug the TA callbacks, it forces the DLL to simulate the start/end of a TA.
