Page 4 of 25 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 248
Thread: siLABS RADIO PLUGIN
  1. #31
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by GizmoQ View Post
    Tried this today on my 500Mhz tablet and CPU spiked to 100% as soon as menu.skin loaded. Never came back down. So couldn't get to iceradio.skin.
    Make sure you have the wait.skin in your skin folder, this is always needed when loading plugin's as far as I know. Without it it will just lock up.
    Also the main problem with a radio plugin again as far as I know will only work when the plugin is active, so say your listening to the radio, then want to goto your gps screen, you cant still listen to the radio.. this is why I looked at coding it in native and still think its the best way to do it. If you need a hand transfering your code into RR then give me a shout as I can certainly help you there..
    ~CdR
  2. #32
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by CdRsKuLL View Post
    ~CdR
    CDR,
    I have to disagree.
    This is an extension plugin. You can load the extension plugin in your first screen and it will be active all the time. It basically adds new labels, commands, sliders and indicators to the set of RR. You do not need a wait.skin at all. When the dll is loaded RR will for every label call the ReturnLabel function in the dll to see if the dll support that label. If not it will continue to check the labels native in RR.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  3. #33
    Apr 2005
    The Netherlands
    Quote Originally Posted by 84RegalRider View Post
    I got a question.
    silabs lags by like 2 seconds (went to the drive in )
    is there anyway to fix it with the dll or is the radio just slow???
    thanks if you got any info.
    What I understand from the design of the radio is that it does not need an line in to your computer because the microcontroller on the stick does an Analog to Digital conversion that is being send to the computer over USB. I guess that's where the lag is comming from. Normally this would not be a problem but it's interesting to hear how you came across yours.
    This will probably mean that there not much that can be done about it. However 2 seconds behind is much.
    I have noticed something else too. When my CarPC is very busy at time I seem to miss some of the receiption. It's far less than a second but you can hear it. Just like it skips a track on the CD player because it's dirty.
  4. #34
    Apr 2005
    The Netherlands
    Quote Originally Posted by RS200Z View Post
    Hi, I am still experiencing high CPU problem as reported here:
    Silabs USB Radio bugs thread
    I guess Guino doesn't own a Silabs radio to be able to troubleshoot the problem. Are you able to help?
    I'll make a copy of my skin tonight so you can try that out. Please also check that the USBRadio.dll is replaced by the one in the zip and the plug dll is registered correctly.
    Does your radio work with the silabs sample application?
  5. #35
    Mar 2005
    Sweden/Vaxjo
    Just wanted to say... YES!
    finally some way to get the Traffic Information into RR... thats the thing that I've missed the most since I ditched my old HU...
    now I just need to get my Silab's radio!
    Swedish site for CarPC's
    http://www.bilpc.info
  6. #36
    Apr 2005
    The Netherlands
    Update post #1. New version available for download.
  7. #37
    Apr 2005
    The Netherlands
    Quote Originally Posted by 307SW_NLD View Post
    You can download the complete skin I'm using from
    http://gpsirda.dyndns.org/iceRadio/HyundaiV1.00.zip
    Slow bandwidth sorry. File is about 10MB
  8. #38
    May 2005
    Hi, perhaps you misunderstood me. I did managed to get the radio to work in RoadRunner as well as the Silabs Radio application. I am not having problem listening to radio.
    What I am having problem with is when radio is playing in the background, my skin buttons which switch focus (via the ACTIVATE command) to 3rd application to send key stroke does not work all the time. This problem does NOT exist if radio is not playing in the background.
    To confirm that it's a RoadRunner issue, I stop the radio from RoadRunner and used the Silabs Radio application to start the radio again. With the Silabs radio application still running, my skin buttons works EVERYTIME without a hitch which was the case before I had the Silabs radio.
    I am experiencing this in both my home and CarPC.
  9. #39
    Apr 2005
    The Netherlands
    The only thing I can think of is that between the ACTIVATE and the sendkey another command was send from the plugin causing RR to get focus again.. Maybe Guino is say something about that..
  10. #40
    Apr 2006
    I have also given the program a run. The main reason I wanted to use it was for the rds text which, while not yet perfect, is worlds better than what the other .dll was giving me.
    What I have noticed though, when I start RR, the radio bleeps on briefly.
    On resume sometimes the radio and audio start at the same time.
    And finally, if I don't have audio playing and I start the radio, it starts moth.
    (Maybe the last two can be solved using the 'status' label which shows play/pause/stop. I'm probably going to write this into my skin since it's annoying me but thought you'd want to know in case you wanted to incorporate it)
    Great program though!
  1. radioSHARK Plugin for RoadRunner
    By Evolution VIII in forum RR Plugins
    Last Post: 09-30-2007, 06:55 PM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  3. Replies: 17
    Last Post: 10-29-2006, 11:55 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Sirius Radio Plugin...
    By ThermoDust in forum Centrafuse
    Last Post: 08-27-2005, 09:20 PM
