Page 6 of 25 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 248
Thread: siLABS RADIO PLUGIN
  1. #51
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by 307SW_NLD View Post
    1. Do not set RadioMode to 7 in RR.INI
    What do you set it too then ? I've already changed mine......
    Terran
  2. #52
    Apr 2006
    zero works
  3. #53
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    any setting will do as your not using the radio bit, so it doesnt matter at all
    CdR
  4. #54
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    when will it be true, that i can use a ADS stick with roadrunner.
    and its equal for me if its out or inside roadrunner. i need a result.
    and no, ice radio didnt work with it, and the usbradio.dll only shows me the name of the station, but i want all.
  5. #55
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    documentation says to run >cmd then change to RR directory and type regsvr32 RR_ICERADIO.DLL
    Well no such dll is in the zip file.......
    USBRadio.dll is in the zip, but that one fails with a 'cant find entry point'
    whats going on...........
    Lez, more widely known as flez1966
  6. #56
    Aug 2005
    germany
    Quote Originally Posted by lez View Post
    if you read the documentation, there is nothing who told you to regsrv the usbradio.dll, or ?
    why you try it.
    you only should register the rr_iceradio.dll, make the entry in the menu.skin and insert the order in your exectbl.ini, nothing else.
    if you use the silabs stick, the iceradio is near perfect. you can work with all parameters who are written in the help file.
    if you look to post #1, you find a link for the last 1.06 version. it works and its complete.
  7. #57
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by GF-ler View Post
    why you try it.
    maybe I'm stupid.
    And I have found I accidently deleted it while unzipping it.......
    Doh:
    Apologies everyone.......
  8. #58
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    It tells me (uk)radio 1 is a country music station..........
    I guess its only decoding the RDS data (in this case PTY 10) to an american lookup table, maybe we need a UK dll (hint) with the table entries changed to suit..........(not 'now' I'm not complaining, but later etc, just so its 'right')
    Wonder how is this going to affect the probablity of TMC, because that will be different, why the standard had to be reinvented is beyond me...
  9. #59
    Jan 2003
    TMC is only in the EU... the US has some other name I can't remember...
    Re RDS - its an international standard so should be correct.
    Terran
  10. #60
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by ccsnet View Post
    Terran
    Tomato'e tomato all over again.........
    the lookup table is different for european / US station classification, of course they are the same (almost) but in a different damn order so two tables are needed to do it right............
    I thought the US had TMC on FM?
    I know we have it carried on the back of classic FM and associated stations under the parent company, and I think radio 1
    tables.
    http://en.wikipedia.org/wiki/Radio_D...#Program_Types
  1. radioSHARK Plugin for RoadRunner
    By Evolution VIII in forum RR Plugins
    Last Post: 09-30-2007, 06:55 PM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  3. Replies: 17
    Last Post: 10-29-2006, 11:55 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Sirius Radio Plugin...
    By ThermoDust in forum Centrafuse
    Last Post: 08-27-2005, 09:20 PM
