Page 8 of 25 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 248
Thread: siLABS RADIO PLUGIN
  1. #71
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by 307SW_NLD View Post
    This is the only skin because it's using its own defined labels, indicators and buttons. Check the skin file to see which I have used. It's relative easy to replace the labels, buttons and indicators of another skin to be able to use the plugin.
    Uhmm! I don't get sound at all from any other skin, i wouldn't have thought the problem was related to the label comands and such.
    I'm going to go mess with it, thanks for your help.
  2. #72
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by GF-ler View Post
    is there no way to make it possible to use your iceradio with an ADS stick ?
    I'm using the USBRadio.dll. If you have modified USBRadio.dll (with support for ADS) I see no reason it should not work. I have tried the modified USBRadio.dll myself and I got no errors. I do not have an ADS so I can really say it working.
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  3. #73
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    perhaps its a missunderstood, but i think your iceradio only runs with your usbradio.dll.
    and your usbradio.dll from version 1.01 or 1.06 didnt run with my ADS stick.
    the same is with guinos usbradio.dll, it doesnt work with my ADS stick.
    which USBradio.dll runs, is the version which comes with the TestSilabs and one which is dated by 27.04.07 08:02.
    but both of them gives me only signals for RDSText, RDSStation and RDSSignal........ but i want all whats possible with this stick.
    and your iceradio is my favorit in this way.
    on your iceradio application i like the lot more signals in/out and that i can make 30 stations for selection in a list. here is the _down screen from my RENESIS skin for your iceradio signals. fill it with life, please.
  4. #74
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    I try this but it doesn't work for me
    config:
    RR.ini > radiomode=0
    ice_radio.dll in rr DIR and regsrv32 is done
    usb_radio.dll in RR dir (ADS compatible!!)
    X,ICE_RADIO in your sample skins first line...
    but don't work..
    could anybody hlp?
    thx
    Englishlessness :(
  5. #75
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    I like your skin you wanna share it :
    ce:
  6. #76
    Aug 2005
    germany
    Quote Originally Posted by tn6478 View Post
    ce:
    did anyone know a adress in the euro zone where i can buy a silabs stick ?
  7. #77
    Apr 2005
    The Netherlands
    I see your skin is using 12 presets. But my plugin has only 10 presets per screen which you can switch by using the radio_band button (like a normal headunit has FMI, FMII and FMIII.
    I'm willing to help to get the ADS Radios working. I have setup a development environment and I am able to build my own usbradio.dll using a code example. But I need to know what to change in the dll to make it work for ADS as well.
  8. #78
    Apr 2005
    The Netherlands
    OT
    this skin is a RX_8 skin. i draw it once for guino, but he never gives me a answer.
    as i make a copy to a rapidshare folder i open a new thread with the link for loading.
    Attachment 43030
    Try farnell.de
    http://de.farnell.com/jsp/search/bro...usb+radio&Ntx=
    to be exact
  9. #79
    Aug 2005
    germany
    thanks a lot for the link.
    i will wait if you can make it possible that i work with the ADS stick.
    yes i know it with the 12 buttons for station seletion, button 11 would be a reserve switch and button 12 for ... next 10 stations... and i know that you use the FM button... but it looks better with 12 in the box.
    i think GuMiSZu gives a link with the source of the USBRADIO.dll with ADS support.
    once again thanks for your help.
  10. #80
  1. radioSHARK Plugin for RoadRunner
    By Evolution VIII in forum RR Plugins
    Last Post: 09-30-2007, 05:55 PM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 12:32 PM
  3. Replies: 17
    Last Post: 10-29-2006, 10:55 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Sirius Radio Plugin...
    By ThermoDust in forum Centrafuse
    Last Post: 08-27-2005, 08:20 PM
