Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
Thread: RRCam - Video camera display and record
  1. #11
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    i would love to check out yours beezer, but i cant get to it on this computer (govt comp.) i think in a day or so i should be able to, and will give it a look. in the meantime, i started re-writing mine, just for kicks really. if nothing else, i may just use it personally. or at least keep working on it until i get my fusion brain and start cutting code for that =]
    ill post here when i have a decent .exe to share =]
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  2. #12
    Constant Bitrate Beezer's Avatar
    Oct 2006
    Well, if you check mine out, the interesting things are the callback hooks. They are enabled in the onLoad on the main form. The callback modifies each video frame but in the case where the video is compressed, it seems to ignore my modifications.
  3. #13
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    i'd be glad to check it out, but you'd have to email it to me, and change the extensino form .zip to .jpg to get past the filters
    inh at burntmail dot com if you want =]
  4. #14
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Quote Originally Posted by Enforcer View Post
    Yeah that crashing when using the RR SDK comhook. I have that issue as well. Howver I have some apps which don't do that and some that don't. Try using the com object (I haven't yet but will soon).
    I took a look around the baseplugin sources to see if it used a differnet
    method of communicating with RR. I was bummed to see it still used the
    comhooks that i've been having so much trouble with, but then I noticed
    something a bit different about how they were used:
    Code:
    Private Sub Form_Load()
    On Error GoTo InIDE
        'Hide COM form
        Me.left = -(Me.Width + 100)
        Me.top = -(Me.Height + 100)
        Me.Show
        'This causes an error in the VB IDE (but not on runtime)
        'I got tired of crashing the IDE while debugging RR because of the COM hooks
        Debug.Print 1 / 0
        COMHook Me.hwnd
    InIDE:
    End Sub
    So I added that to my app:
    Code:
    On Error GoTo InIDE
        Debug.Print 1 / 0
        COMHook Me.hwnd
    InIDE:
    'the rest of my app initialises here...
    and it works fine! hasnt crashed so far when i compile a .exe and run it, and it doesnt crash VB anymore =]
  5. #15
  6. #16
    Jun 2003
    Memphis - TN
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  7. #17
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    i have ver 1.0 ready to release, but because im stuck on a govt computer i cant send or recieve .exe or .zip files.. If i rename a .zip to .jpg it works fine, but the firewall software still scans inside it and sees a .exe file.
    I'm going to try a few different formats, but i may end up having to email it to someone with the .zip renamed to .jpg, and the .exe in the zip file renamed to .jpg as well.
    anyone out there willing to send me thier email address so i can have them rename those certain files back to how they should be and upload it somewhere so i can share it here?
  8. #18
  9. #19
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Email sent =] Thanks!
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Here goes then, this is inh's RRCam
    There's a readme file that should get you started in the same directory as the exe, but basically, just extract to your skin directory.
    Attached Files Attached Files
  1. Reverse camera query: USB webcam or mini "spy" camera?
    By SamDude in forum General Hardware Discussion
    Last Post: 07-13-2007, 02:10 PM
  2. How do I setup TV / Camera Support ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:42 AM
  3. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
