Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
Thread: RRCam - Video camera display and record
  1. #21
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Quick bump and a note to check the first post =]
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  2. #22
    Feb 2007
    Croydon UK
    twin cams
    i've finally got to the stage for the cameras now ,so what i hope can be done if pos.
    i after away to have 2 cameras on the same skin window, front and reverse,
    would this be possiable.
    thanks
  3. #23
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Should be possible, though im not sure if the computer would ahve the proccessing power to record at a decent framerate. But for displaying, no problem at all. If all you want is two cameras I could whip that up quite fast in its own application. Is there anything specific you're looking for?
  4. #24
    Feb 2007
    Croydon UK
    not really
    all i would like to do is say have a split screen in 1 skin so i can see front and back of the car at the same time.
    i was'nt thinking of any recording on 1 camera (reverse) don't see the point really but may use the record on the front camera. and the mirror func. on reverse is a good idea.
    if you can do this it would hansome. would i have to use 2 different (drivers) cameras, and would you be able to tell the window name so i can add it to the skin i useing.
    thanks again
  5. #25
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    If you just want to display what the camera sees, with no mirroring or recording, i can upload something in a few mins ( i started working on it not too long ago) just gotta iron out some details.
    recording and mirroring go hand-in hand (they require mostly the same functions and what not internally) so it would take a bit longer for that, then it can happen, though I do plan on adding multiple camera support to RRCam in the not so distant future.
    let me go knock out this dual cam setup, and ill upload DualCam.exe (which is also the window name) and config.ini which is needed to setup which cameras display on each half.
    You also need seperate cameras and probably drivers for it to work. I'll add in a TestMode setting in config.ini so it will tell you what drivers you have available to choose from.
    be back in a few!
  6. #26
    Feb 2007
    Croydon UK
    excellent
    "rubbing hands together" imaging is my foremost at the moment,
    mirror and recording can come later,
    again thanks
  7. #27
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Here ya go!
    You'll have to rename DualCam.doc to DualCam.exe and config.txt to config.ini (had to do this to get around the firewall here) make sure that the exe and config.ini file are in the same directory. You can try running it as is and it should work, but if not you may need to change the driver numbers in the config file, so open it up, set TestMode to True, and then run it again, it will give you a list like drivernumber - driver name for you to plug in to the config file =]
    Oh and the window name is either DualCam or DualCam.exe, i cant quite remember.
    Attached Files Attached Files
  8. #28
    Feb 2007
    Croydon UK
    thanks
    will give a whirl, just waiting for mate to come round with a second camera.
    i'll keep you informed
    I'll get a nice transparent PNG skin out (feel free to make one =])
    i use a trans. skin , and because i am no good with photoshop or gimp, all i have done is copyied another skin from my file and used label/buttons i have a fullscreen skin here with just the player buttons and back to menu buttons at the bottom or this 1 which i think i might use for your rrcam.at the top is Gatsohunter the labels are buttons as well.
  9. #29
    Feb 2007
    Croydon UK
    error on daulcam
    i ran the pluging you posted for Daulcam.
    upon running got an error of videoOCX.oxc missing or not registered.
    i don't have this file in sys32 folder.
  10. #30
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Whoops, sorry about that. Attached are the two .ocx files. You'll only need VideoOCX, but anyone using RRCam will need VideoOCXTools.ocx as well. Just rename from .txt to .ocx. They should work if placed in the same folder as RRCam.exe or DualCam.exe, but if not, place them in your windows\system32 folder.
    I'll include them in the next release of RRCam
  1. Reverse camera query: USB webcam or mini "spy" camera?
    By SamDude in forum General Hardware Discussion
    Last Post: 07-13-2007, 02:10 PM
  2. How do I setup TV / Camera Support ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:42 AM
  3. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
