Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: Smart PlayLists (aka Smart Views) Plugin - Enables querying of your music library
  1. #11
    Jun 2003
    Atlanta/Augusta, GA
    Quote Originally Posted by JohnWPB View Post
    I took it one step further. I added some code to a button, that pop's up the On Screen Keyboard. You can then type a search string such as a portion of a song name ect.
    Excellent idea! Can you post the relevant commands or a patch file?
    If I get some more time, I'd like to take that even further and do something like DJIK's Jump 2 File Plugin. I really miss the "j" function of winamp and would love to have an easy way to query the entire medialibrary to find and play or enqueue any mp3 using an OSK.
    Quote Originally Posted by kbreeden
    Some of us have trouble with Winamp 5 in RR. Do you know if this will work with 2.95?
    Sorry, this will not work with 2.95, since it does not have the medialibrary (music database) feature that was introduced with Winamp3. What trouble are you having with Winamp5? I may be able to help diagnose or post a patch.
    Other future work for those with VB skills:
    It's possible to rewrite Road Runner's winamp control module to use the activewinamp plugin exclusively. This should give RR more control over winamp (access to more APIs like medialibrary calls) and make it more responsive (e.g. you could manipulate the playlist in memory instead of the playlist .m3u files on disk). It may break a few skins or plugins that don't use the RR winamp API exclusively, but a VB expert could knock it out in a few hours most likely. It would make querying the library even quicker and may even help those that are having problems with winamp5 out.
    Unfortunately, I don't know much about VB or windows programming in general (thanks Georgia Tech ), so I haven't attempted it. I got a couple more weeks to take a stab at it before classes pick back up, but anyone else want to volunteer?
  2. #12
    Jun 2002
    Virginia
    Quote Originally Posted by tejesh83 View Post
    I'm with you. That capability would make you a hero around these parts.
    For some reason, in my carputer I get random lockups of RR when using Winamp 5. It's all the more perplexing because it doesn't happen on my desktop. I appreciate your offer to do a patch, but I can't imagine what the patch would be because I don't know what's causing the problem. I think I'll try 5.13 again and see what happens.
    Sounds great. Unfortunately, that work is way above my skill level.
  3. #13
    Jun 2003
    Atlanta/Augusta, GA
    Quote Originally Posted by kbreeden View Post
    Here are some things you can try if you still have issues with 5.13:
    1. Uninstall winamp and delete the winamp directory in Program Files.
    2. When installing winamp, uncheck all the extra features except the bare necessities like media library and directsound. This will install less plugins, and hopefully make your winamp more stable.
    3. Finally, in the plugins output menu, select directsound, and try turning off H/W acceleration, since its buggy with some sound card drivers.
    You can also try the winamp forums. There may be a way to enable debugging and have one of their developers help you out. I found a lot of good info their when working on this plugin.
    I just started using winamp5 in my carpc, so I can't vouch for its stability yet. I'll keep you posted and hope you do the same.
  4. #14
  5. #15
    Jun 2002
    Virginia
    Thanks for the advice. I'll give it a try.
  6. #16
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    OSK to search the Database
    There has been no alteration to the script needed whatsoever, just how the information gets passed to the script is all.
    As far as the JTT, this replaces it completely. The only thing it does not do, is show the songs as you type the name. On the MAJOR plus side, this method is completely skinnable, and works 100% seamlessly with Road Runner.
    All that is needed is for these 2 lines to bring up the OSK to search for text in the title of a song, to be added to the ExecTbl.ini file.
    Code:
    "SearchForSong"," ||OSKTOCMD;MySearch;SearchSongTitle"
    "SearchSongTitle","RUNQW;wscript.exe" "$rrpath$\SmartPlayLists\queryWinamp.vbs" "$winamppath$" "title HAS "$MySearch$"" "||RELOADLIST||Load;Audio_Playlist.skin"
    Then all you need for the Button code is the following:
    Code:
    "SearchForSong"
    When its all set up, it works like this:
    - Press the search Button
    - The OSK pop's up and you type in a search word, "Rock" in this example
    - In only a second or 2 it kicks you to the playlist screen with all the search results (MUCH better than the minute or so for Road Runner to search the hard drive!)
    Here is the result of the "Rock" search:
    My Fiero Build Thread
  7. #17
    Nov 2005
    Awesome work on the plugin!!
    Anyone using Freedom 2.1 willing to make a suitable skin for this?
  8. #18
    Nov 2005
    I noticed that in Winamp, if you type in your search criteria and then Right-click on one of the results, you can either load that particular song OR you can load the entire album (if its part of an album) which that track belongs to.
    Are these two options possible with this plugin?
  9. #19
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    The way this plugin works, is when you do a search for "Rock" for instance, every song containing the word "Rock" is added to an on the fly playlist. So when you look at the results, you can either double tap to play a song in the list, or it will just play the songs in the newly created playlist in order.
    Being this is the way it works, you could type "Pink Floyd" and every single Pink Floyd song, no matter what sub folder they are in, will be made into a playlist.
    Basically you just need to mind what you are searching for, to get better results.
  10. #20
    Nov 2005
    Thanks John. I have a lot of songs that are part of compilation albums (eg: Ministry of Sound - Sessions). I search for a particular song, which I find, but I decide that rather than just play that 1 track, Id like to load the entire album - and listen to it as it should be heard. Thing is, I dont know which album its on, so I cant search the album alone. (Also, I cant search via album with this plugin anyway, I dont think. Further more, I heaps of 'Ministry of Sound' albums, so it will be hard to search that way too.). Any suggestions on how I can overcome/fix this?
    I really like the way winamp does it at the moment (in Winamp V5), if you've tried it?
  1. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Boolean Operators in Smart Playlists
    By shakes in forum FrodoPlayer
    Last Post: 05-09-2005, 02:08 PM
  4. Smart Playlists
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 05:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
