Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: RRCam 1.1 Video display/record with text overlay
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Finished up RRCam 1.1 a few minutes ago. Fixed a bug or two, as well as added the ability to overlay date and time, and your own custom text =]
    Download the attached RRCam1.1.txt file, but save it as RRCam1.1.zip (or rename it after you download it.) Then unzip the file to your skin folder. Next make sure you run RRCam-RunMeFirst.bat. This renames the file RRCam.jpg in the RRCam folder to RRCam.exe because the firewall here wont let me upload .exe or.zip files.
    Included is a very poor sample skin to get you started, or you can run RRCam.exe right away, as TestMode is enabled by default and buttons to control it will show up. Check out config.ini to change the default custom text as well as many many other options =]
    EDIT: Made a few quick changes to RRCam1.1.txt attached below
    EDIT: More changes Just ironing out the small bugs. Should be good to go for now (until the next release )
    Attached Files Attached Files
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
    Jan 2007
    will test it right away, tnx
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    No prob =]
    Jan 2007
    So far it looks great! only:
    1. if i leave the video to 8 fps it will not record, i get an videoocx error
    2. the recorded video file is corrupt it seams (as DIVX and as MSVC)
    but i will check on those things again, because maybe it's my pc
    edit:
    error 2 seams only to be happening if i close RR and the app is still running, i guess it doesn't like to be closed by RR. If i press record the file is closed and 100% ok.
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Ah! I will change the default to MSVC (forget that not everyone has DIVX)
    Also, the 8fps is wierd, I havent had any issues.. What happens if you set it lower or higher?
    Jan 2007
    Quote Originally Posted by inh View Post
    if i set it to 25 it works perfect, seams a bit strange, but i record it on 25 fps anyway so no prob for me
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Hmm.. I always had an issue with that. If you record ten seconds of video at 25 fps, and then play the video file, does it take 10 seconds to play back? if i do that on my computer, the file plays back in like 2 seconds, because the software cant add the frames to the video fast enough. Thats why I have it set to 8...
    about your second error, that might be a lack of foresight on my part.. Let me double check the code to make sure it properly closes the video file when RoadRunner exits...
    Jan 2007
    you are right, if i leave it on 25 time ticks faster. I will play a bit with these settings
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Guess I should make that a bit more clear in config.ini
    Also, I changed the default to MSVC and changed the code for the exit menu to tell RRCam to exit, and then have RoadRunner close RRCam, then display the exit men. That should fix the problem with the corrupt videos.
    Code:
    B,98,526,99,78,""SENDMSG;RRCam.exe;EXIT||CLOSEWINDOW;RRCam.exe||EXITMENU",
    When you send the message EXIT to RRCam, if its recording, it will stop and close the file, so it wont be corrupt =]
    Jan 2007
    Code:
    Yes, this works (you are fast ) but another problem is that when RRcam is running an the pc gets the command to power down, it will close RR. But before RR is closed RR closes all the programs it opened, in this case RRcam, but RRcam doesn't get the right closing command so the file is corrupt.
    Maybe i can tell RR to close RRcam with the right parameters, i will search if there is any option available to do so
  1. Trouble with PCI video card install ... help!!!
    By DonkeyBoy in forum General Hardware Discussion
    Last Post: 08-10-2005, 05:22 PM
  2. Video recording sw with GPS overlay capability?
    By ambush in forum General MP3Car Discussion
    Last Post: 07-21-2005, 07:53 AM
  3. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 10:17 AM
  4. Video Overlay
    By cadence117 in forum MediaCar
    Last Post: 08-28-2004, 10:34 AM
  5. VIA onboard video overlay settings
    By Nanozic in forum General Hardware Discussion
    Last Post: 07-23-2004, 01:55 PM
