Results 1 to 3 of 3
Thread: Fusion Brain Integration
    Jul 2007
    Hi,
    i want to integrate 2 FUSION BARIAN circuits in RR ,
    1st button in main page : FUSION BRAIN Circuit 1 Skin Should appear,
    2nd button in APP-button on the main page : FUSION BRAIN Circuit 2 Skin Should appear,
    Iam using these 2 circuits to control my external stuff..
    Plaese help me how to add these two in ROAD RUNNER.(Newbie)
    Thanking you,
    Michael..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I believe you're talking about the control application for fusion brain. You just need to edit the buttons to load the application inside RR so you can control it. Read up on those:
    http://www.mp3car.com/vbulletin/rr-f...in-screen.html
    http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
    more can be found Here
    Ride Runner RR's Myspace
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by michael2 View Post
    Hi,
    Thanking you,
    Michael..
    Im not quite sure what you mean. Are you trying to use 2 instances of the program? If so, you must have 2 copies of the progam in different folders. It may work off of the same copy, but I doubt it will because there will be dll conflicts.
    Or do you want 1 instance of the program but have buttons in RR change the page in the Fusion program?
    As of now for #2, there is no way. I am writing a COM object so that you can do it via the standard RR COM way. I havent gotten very far yet because I am working on a seperate more pressing issue with Vista compatability.
    1.9in x 2.9in -- 47mm x 73mm
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. using fusion brain to delay turn on of amp
    By theheel in forum Fusion Brain
    Last Post: 08-27-2007, 10:33 PM
  3. User Manual for Fusion Brain
    By greenman100 in forum Fusion Brain
    Last Post: 07-07-2007, 01:31 PM
  4. Car Alarm with your Fusion Brain ?
    By Fiberoptic in forum Fusion Brain
    Last Post: 07-03-2007, 02:56 PM
  5. *Available for Preorder* Fusion Brain USB I/O board
    By greenman100 in forum Hardware Development
    Last Post: 05-22-2007, 10:14 AM
