Results 1 to 10 of 16
Thread: send position data to any server in real time
    Sep 2007
    Hi,
    i'm going to write a plugin, that sends aktual position data (and maybe other) to any (mysql-)server (www or ras). Transmission should be via GPRS cause of cheap flatrates. Someone who is interested ?
    mlsoft
    Mar 2007
    Australia
    hey
    sounds good, i'm in.
    i've done a little bit of programming myself, heading into mobile devices and such atm.
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    I played around w/ the same thing and had it run on web services/XML so you can easily make it run on any platform, web server, language, etc.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Sep 2007
    Actually it gets data from MapMonkey's API. Written in Visual Basic 6.0.
    Here some Features i plan or i have written now:
    - transmission of coordinates, heading, speed, direction, timestamp
    - tourid, maut-information, info about load (for german commercial use)
    - car-identifier
    - timestamp
    What i need:
    Someone who creates skins for embeddes using in MapMonkey/RoadRunner
    mlsoft
    Sep 2007
    of course there are more things that this software does:
    - Every xx seconds it writes actual data to local database to transfer oder view later
    - internet- or ras- connection i handle dircetly wihout microsaft connection-manager (is not reliable enough)
    - by holding connection it is possible to send real GPS-data directly to any server to store or visualize e.g. for racing purpose / realtime tracking
    mlsoft
    Jun 2004
    Virginia
    i used the api in mapmonkey because its very easy to use, however i switched iGuidance recently. Look into reading the memory address of programs to get the GPS coordinates (I can't tell you how to do this, as i did not get that far). You'll be able to use any GPS software w/ your program.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    GPS Tracking Log
    Quote Originally Posted by warnockm View Post
    There is no reason to pull the GPS info from either Map Monkey, or iGuidance. RR has this information built into it. Just use the RR labels:
    "GPSLAT" - GPS Latitude
    "GPSLON" - GPS Longitude
    "GPSSPD" - GPS Speed (In whatever units specified in RRConfig -- Mi/h or Km/h)
    "GPSHDG" - GPS Heading (in degrees only)
    "GPSALT" - GPS Altitude (In whatever units specified in RRConfig -- ft or m)
    "DATE" - System Date
    "TIME" - System Time
    This would make the plugin universal to any GPS software that users may be using with RR, Streets & Trips, Map Point, Destinator, Free Drive, NRoute, iGuidance 2.x, 3.x, 4.x..... you get the idea
    My Fiero Build Thread
    May 2005
    Vienna, VA
    Yup, just pull the coordinates from RR as John said. Memory addresses in iGuidance jump around a lot so it's not reliable (I've tried this method when I was trying to parse the street names in IG).
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Jun 2002
    Malaysia
    I agree, just pull the coordinates from RR because its standard and not platform dependant.
    Jun 2004
    Virginia
    Quote Originally Posted by masch View Post
    i didn't realize this was an RR plugin. If you are running RR, then thats a great way to go. if not, use xport to copy another comport and read the raw GPS data.
  1. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 04:08 AM
  2. Replies: 5
    Last Post: 09-08-2004, 12:38 PM
  3. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 08:24 PM
  4. gps tripmate position time?
    By schrodos in forum General Hardware Discussion
    Last Post: 11-29-2000, 01:21 AM
