many thanks for using "CUSTOM" and not "!" for the indicator. I think the ! need be abolished lol.
Excellent work! Thanks to all who contributed
Can't wait to try this out now.....
Live mp3Car Facebook Chat
true, using "CUSTOM" is a lot easier to interact with flash.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
CD file extension checking (insert an audio/mp3/what every extension it will play--a cd with just files/documents is ignored). This seems to work for me. It does some extension checking via the ini file. Would it be better if it pulled the playable extensions from rr.ini? I'm new to autoit, but not new to simple programming so be niceIf this looks good I'll see about adding some video playing from CD's, or maybe look at a way to detect the media inserted as video/audio/dvd without CDFS and UDF--to add the ability to use this on a usb drive.
This is added to the ini:
CDEXTENSION=.mp3,.wav,.wma
Code:; Written by JohnWPB of the MP3 Car Forums 9/12/07 ; This script will monitor your CD/DVD drive ; Looking for a CD or DVD to be inserted and ; will then auto play it inside Road Runner. ; When a CD is inserted, it will save your current ; playlist to a temporary file. When the CD is then ; ejected, it will then reload that playlist. Dim $DiskInserted Dim $DiskType Dim $DriveStatus Dim $TypeDisk ;Open communications with RR $rr = ObjCreate("RoadRunner.SDK") ; Read the lines from the AutoLaunch.ini $MyDrive = IniRead("AutoLaunch.ini", "Auto Drive Settings", "CDDrive", "NotFound") $DVDCOMMAND = IniRead("AutoLaunch.ini", "Auto Drive Settings", "DVDCOMMAND", "NotFound") $CDCOMMAND = IniRead("AutoLaunch.ini", "Auto Drive Settings", "CDCOMMAND", "NotFound") $CDEXTENSION = IniRead("AutoLaunch.ini", "Auto Drive Settings", "CDEXTENSION", "NotFound") $CDCOMMAND = "LoadList;" & $MyDrive & "||" & $CDCOMMAND $CDExt = StringSplit($CDEXTENSION, ",") While 1 $DiskType = DriveGetFileSystem($MyDrive) If $DiskType = "UDF" And $DiskInserted = "no" Then ;MsgBox(4096, "Drive Status:", "A DVD Was inserted") $rr.Execute($DVDCOMMAND) $rr.Execute ("SETIND;CUSTOM_DVDIN;ON") $DiskInserted = "yes" EndIf If $DiskType = "CDFS" And $DiskInserted = "no" Then ;MsgBox(4096, "Drive Status:", "An Audio CD Was inserted") For $count = 1 to $CDExt[0] If FileExists($MyDrive & "*" & $CDExt[$count]) Then $TypeDisk="CD" $SavePLCommand = "SAVELIST;$SKINPATH$TempPL.M3u" $rr.Execute($SavePLCommand) $rr.Execute ("SETIND;CUSTOM_CDIN;ON") ; Pause for 2 seconds, give RR time to catch up and save the playlist to disk sleep(2000) $rr.Execute($CDCOMMAND) $DiskInserted = "yes" EndIf Next EndIf $DriveStatus = DriveStatus($MyDrive) If $DriveStatus = "NOTREADY" Then $rr.Execute ("SETIND;CUSTOM_CDIN;OFF") $rr.Execute ("SETIND;CUSTOM_DVDIN;OFF") If $TypeDisk="CD" then ;MsgBox(4096, "Drive Status:", "an Audio CD Was Ejected") $LoadPLCommand = "LOADLIST;$SKINPATH$TempPL.M3u" $rr.Execute($LoadPLCommand) $TypeDisk = "None" EndIf $DiskInserted = "no" EndIf Sleep(2000) WEnd
CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
MediaLaunch for RR
Online Check for RR
Locker for RR
Hey John,
I get this error occasionally when I eject the CD:
any ideas?
MSI K9N6GM
1 gig RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
the only problem i have is the eject command,
is it path specific because its ejecting the wrong drive.
this is on a laptop with built in drive and a usb drive, the usb drive iis the 1 up front of the car, so guess what its the 1 i want to use.
but the eject command ejects the built in 1 not the usb 1
i dont believe there is a way to specify which drive you want to eject thru rr. If you dont uset he drive on your laptop just disable it thru device manager and rr will eject the external one.
i think road runner ejects the first drive, and also i remeber having some issues with mine, if i leave it running all the time, thats why i use only when ejecting to fire up the script, and to eject the same drive specified in the ini.
for the guy doing the extentions, use this instead of reading the ini, if you want to read audio extentions supported by roadrunner, same way for video extentions.
this way all the extentions that are in rr.ini under audiofiles will be used, remember the user from user settings.Code:$CDEXTENTION=$rr.getinfo("=$audiofiles$")
Nice addition, will work on getting this implemented with changes I have made here.
I forgot to put an error routine to see if RR has been closed or not. This will in in the next version
On another note, Liquid Smoke added some code to it, that will remember the song playing in your playlist when a CD is inserted. Meaning, if you hav e a10 song playlist, and are listening to the 8th song, when a CD is inserted it will save this info. When the CD is ejected, it will go back to song 8, and not to the beginning of the playlist.
I have quite a few tweaks, additions and code to test and add before I put another beta of it.
My Fiero Build Thread
try this to see what type of media is in the disc, whatever extentions you have in rr.ini under "audiofiles" and "videofiles", will be found including subfolder's.
Code:#include <Array.au3> dim $extarray, $output, $audio, $q, $video, $a $rr=ObjCreate("RoadRunner.sdk") $audext=$rr.getinfo("=$audiofiles$") $MyDrive = IniRead("AutoLaunch.ini", "Auto Drive Settings", "CDDrive", "D:") $vidext=$rr.getinfo("=$videofiles$") $AUDfound="NO" $VIDfound="NO" $audio=StringSplit($audext, ",") $video=StringSplit($vidext, ",") $search1 = $Mydrive&'\*'&(StringReplace($audext, ",",'*;'&$Mydrive&'\*'))&'*' $list1 = _Filesearch($search1, 1) if ($list1[0]) > 0 then ;MsgBox(0,"",$list1[0]&" Audio Files Found"&@CRLF) $AUDfound="YES" EndIf $search2 = $Mydrive&'\*'&(StringReplace($vidext, ",",'*;'&$Mydrive&'\*'))&'*' $list2 = _Filesearch($search2, 1) if ($list2[0]) > 0 then ;MsgBox(0,"",$list2[0]&" Video Files Found"&@CRLF) $VIDfound="YES" EndIf MsgBox(0,"","Video In Media ==> "&$VIDfound &" ==> "&$list2[0]& " Files"&@CRLF _ & "Audio In Media ==> "&$AUDfound & " ==> "&$list1[0]& " Files") ;======================================================================================================= ;function created by bchris01 ;======================================================================================================= Func _FileSearch($sQuery, $iSubdir = 0) Dim $aFiles[1] Dim $sLine, $aLine $aFiles[0] = 0 $sQuery = StringSplit($sQuery, ';') For $L = 1 To $sQuery[0] $sArguments = "/a-d /b /on" If $iSubdir Then $sArguments = $sArguments & " /s" $aRaw = Run(@ComSpec & ' /c dir "' & $sQuery[$L] & '" ' & $sArguments, @SystemDir, @SW_HIDE, 2) While 1 $sLine = StdoutRead($aRaw) If @error Then ExitLoop $aLine = StringSplit($sLine, @CRLF) If $aLine[0] > 1 Then For $i = 1 To $aLine[0] If $aLine[$i] = "" Then ContinueLoop ReDim $aFiles[UBound($aFiles) + 1] $aFiles[UBound($aFiles) - 1] = $aLine[$i] Next ElseIf $aLine[0] = 1 Then If $aLine[1] = "" Then ContinueLoop If $aLine[1] = "File Not Found" Then ExitLoop ReDim $aFiles[UBound($aFiles) + 1] $aFiles[UBound($aFiles) - 1] = $aLine[1] Else ExitLoop EndIf WEnd Next $aFiles[0] = UBound($aFiles) - 1 Return $aFiles EndFunc
