Page 10 of 32 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #91
    moahdib's Avatar
    Jul 2000
    Quote Originally Posted by Sonicxtacy02 View Post
    tried using it again on a much smaller folder of files (My R&B genre) and it works.. is there some kind of limit as to how many albums fit? I cant see what else it could be. I'm also a little confused as to how to play the album. If i click the album the album list opens up.. if i click a song in that list it turns green but nothing happens.
    This is in RR? Try clicking on the name of the album and see if that loads the playlist. Also try opening the html in the browser and see if it plays when you click on a song.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  2. #92
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by moahdib View Post
    That is strange. Try downloading these scripts and run the au3 in script editor and let me know which line it is breaking on. I just put a fix to the one mp3 in the folder error as well.
    ID3 tags w/ foreign language on the first and/or second mp3 file of each folder will break the script.. but shouldn't be a script array error like you got. This is because of cddbcontrol tho unable to read tags inside those mp3s.
    And another issue I forgot to mention before... due to the nature of the folder scan code I'm using which is recursive, the xml's are not written if you have a collection more than 600 albums. This is a limitation to the # of recursive calls to the same function that autoit can do.
    that could very well be the problem then cause i have more than 600 albums. Bummer
    Live mp3Car Facebook Chat
  3. #93
    Woodbridge, VA
    Blog Entries
    32
    This is all being done in RR.. when trying to run the .html i get a message about needing AC_RunActiveContent.js
  4. #94
    moahdib's Avatar
    Jul 2000
    You can try splitting up the folders and running the script. Then join the xml's together manually.... until I find a better solution to this. I'm puzzled why it doesn't load the songs in your RR... all its doing is a call to RR using setlistath\album.m3u. Anyone else having this problem?
    My TL CarPC ver2
  5. #95
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Haven't tried it yet, but I only have a few albums here at work.
    As far as the XML compiler is concerned I can do it in VB6, shouldn't have a problem with the number of albums.
  6. #96
    moahdib's Avatar
    Jul 2000
    Hey Sony, try adding these lines to your skin file to see if it fixes your issue about the playlist not loading.
    L,0,0,0,0,,,,,,"RRSCREEN",
    S,-400,-400,1,2000,255,255,255,0,0,0,0,0,0,80,80,80,0,255, 0,,20,"Arial Narrow"
    My TL CarPC ver2
  7. #97
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    moahdib
    it is reading greek tags nicely, well except the artist and album title at the top which shows nonsence.. boxes..
    any idea how to make the swf display id3 tags instead of filenames, for the song that is?
  8. #98
    moahdib's Avatar
    Jul 2000
    Quote Originally Posted by Nomader View Post
    moahdib
    You can maybe find a 3rd party tool that will write m3u files using id3 tags and in unicode text.
    I can't read foreign text in autoit to do that thats why its easiest just to get filenames.
    My TL CarPC ver2
  9. #99
    Jan 2007
    dundee, il
    just tried this out.. i installed per your instructions, try to build the xml with the genre program.. the program files about 75% of my folder.jpgs then errors out with the following message
    the list looks correct for the 75% of albums it finds but when i load the coverflow skin it says "There was an error loading that data, sorry". If i try to use the artist builder again the data looks like it works but i get that same error at the very same point of the xml build.
    My music format is D:\My Music\GENRE\ARTIST\ALBUM\SONG . There are folder.jpg in every ALBUM folder and SONG folder
    i also only get "There was an error loading that data, sorry", my music is sorted f:\dls\music\a\album folder
    david
  10. #100
    Jan 2007
    dundee, il
    not quite sure exactly what i did, but i got it to now display the albums, i can select them (where they flip over) and pick a song to play, but when it loads the song in roadrunner, it also starts playing a second instance of the same song. if i pick a song from the playlist in rr on my audio screen, it plays that song on top of the one i picked in coverflow. i have no idea where the original song is playing, there is only one winamp process running. any ideas?
    other than the trippy dual songs, it looks absolutly amazing
    thanks,
    david
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
