These sources have some fixes from the last released version. I didn't save the au3 from the released ones... I believe it fixes the issue with having one mp3 in a folder which will stop the script from finishing.
Someone take a crack at fixing the scanfolder function bc right now it doesn't support having more than 500 or so albums ( thats what my count was when it broke). Something to do with autoit limit on recursive calls. i apologize ahead of time for the confusion of the script.. I end up writing this stuff very late at night, high on caffeine and often forget where my thought process begin or ends.
Build-Genre.au3
Code:
#include<Array.au3>
#include<File.au3>
#include<SendRR.au3>
Dim $FILEMASK="folder.jpg" ; specify the filemask
Dim $dir
$musicpath=IniRead("builder.ini","builder","path","default")
if $musicpath="default" or $musicpath="" Then
$musicpath= InputBox("Music Folder","Path to your genres folders. Put C:\MUSIC if your directory is structured in this manner:"&@CR&"C:\Music\80s\Albums\"&@CR&"C:\Music\Rock\Albums\"&@CR&"Do NOT put \ at the end. Edit builder.ini if you mess up.")
IniWrite("builder.ini","builder","path",$musicpath)
EndIf
SplashTextOn("Message","Rebuilding XML Data...",500,50,@DesktopWidth/2-500/2,@DesktopHeight/2-50/2,1,"Arial","28","800")
$iswebserver=false ; builds XML with relative paths.
$webpath=@MyDocumentsDir &"\My Music\"
$webpathlen=StringLen($webpath)
$dirlevel=StringSplit($musicpath,"\")
$folderlevel = $dirlevel[0]+1;
ConsoleWrite($folderlevel&@CR)
; Instantiate a COM instance with your new dll
$oId3 = ObjCreate("CDDBControl.CddbID3Tag")
if @error then
Runwait( @comspec & " /c regsvr32 cddbcontrol.dll","",@SW_HIDE)
Sleep(3000)
WinActivate("RegSvr32")
WinClose("RegSvr32")
endif
Runwait( @comspec & " /c del Genre_*.xml","",@SW_HIDE)
if FileExists("FoldersList.txt") then filedelete("FoldersList.txt")
Dim $FolderName = $musicpath
Dim $FileCount = 0
dim $files[200000]
ScanFolder($FolderName)
;MsgBox(0,"Done","Folder Scan Complete. Scanned " & $FileCount & " Files")
Func ScanFolder($SourceFolder)
Local $Search
Local $File
Local $FileAttributes
Local $FullFilePath
$Search = FileFindFirstFile($SourceFolder & "\*.*")
While 1
If $Search = -1 Then
ExitLoop
EndIf
$File = FileFindNextFile($Search)
If @error Then ExitLoop
$FullFilePath = $SourceFolder & "\" & $File
$FileAttributes = FileGetAttrib($FullFilePath)
If StringInStr($FileAttributes,"D") Then
ScanFolder($FullFilePath)
Else
if Stringinstr($FullFilePath,$filemask) then
$files[$filecount+1]=$FullFilePath
FileOpen("FoldersList.txt",32)
FileWriteLine(@ScriptDir & "\FoldersList.txt",$FullFilePath)
$FileCount += 1
endif
EndIf
WEnd
FileClose($Search)
FileClose("FoldersList.txt")
$Files[0]=$Filecount
EndFunc
$Y=1
$count = StringInStr ($files[1], "\" ,"", -1)
$folder = Stringleft($files[1],$count)
$foldersplit = StringSplit($folder,"\")
$lastgenre = $foldersplit[$folderlevel]
$genrename = $lastgenre
$genrenametxt=StringReplace($genrename,"&","%26")
$temp = "list=" &$genrenametxt
ConsoleWrite($lastgenre&@CR)
if FileExists("albuminfob4.xml") then filedelete("albuminfob4.xml")
if FileExists("genre.txt") then filedelete("genre.txt")
if FileExists("genrelist.txt") then filedelete("genrelist.txt")
$fname="Genre_"&$genrename&".xml"
$Falbuminfo=FileOpen("albuminfob4.xml",33)
filewriteline($Falbuminfo,"<?xml version=""1.0"" encoding=""UTF-16""?>")
filewriteline($Falbuminfo,"<artworkinfo>")
For $X = 1 To $filecount
$count= StringInStr ($files[$x], "\" ,"", -1)
$folder= Stringleft($files[$x],$count)
$foldersplit=StringSplit($folder,"\")
$foldercount=$foldersplit[0]
$trackname=$foldersplit[$foldercount]
$genre=$foldersplit[$folderlevel]
$isflac=0
if $lastgenre <> $genre then
;Close File
$Y+=1
$lastgenre=$genre
$genrename=$genre
$temp=$temp &","& $genrenametxt
ConsoleWrite($genrename&@CR)
filewriteline($Falbuminfo,"</artworkinfo>")
FileClose($Falbuminfo)
FileCopy("albuminfob4.xml",$fname,1)
Filedelete("albuminfob4.xml")
$fname="Genre_"&$genrename &".xml"
EndIf
;ConsoleWrite($folder&@CR)
if fileexists($folder&"album.m3u") then filedelete($folder&"album.m3u")
filewriteline("genrelist.txt",$folder)
if fileexists($folder&"*.mp3") Then
$listarray=_FileListToArray($folder,"*.mp3")
elseif fileexists($folder&"*.wma") Then
$listarray=_FileListToArray($folder,"*.wma")
elseif fileexists($folder&"*.flac") Then
$isflac=1
$listarray=_FileListToArray($folder,"*.flac")
Else
$listarray=""
endif
if $listarray<>"" Then
;_ArrayDisplay($listarray)
$trackfilename=$listarray[1]
$file =$folder&$trackfilename
$albumm3u=FileOpen($folder&"album.m3u",129)
For $Y=1 to $listarray[0]
FileWriteLine($albumm3u,$listarray[$Y])
Next
FileClose($albumm3u)
if $isflac=0 Then
; Load the tags
$oId3.LoadFromFile ($file, True)
$sTitle = $oId3.Title
$sLeadArtist = $oId3.LeadArtist
$sAlbum = $oId3.Album
if $listarray[0] > 1 Then
$trackfilename2=$listarray[2]
$file2=$folder&$trackfilename2
;ConsoleWrite("id3file2: "&$file2&@CR)
$oId3.LoadFromFile($file2, True)
$sLeadArtist2 = $oId3.LeadArtist
if $sLeadArtist<>$sLeadArtist2 and $sLeadArtist<>"" Then
$sLeadArtist = "Various Artists"
Endif
EndIf
Else
$sLeadArtist = ""
$sAlbum = ""
EndIf
Else
$dirarray=_FileListToArray($folder,"*.*",2)
;_ArrayDisplay($folder2)
For $Z=1 to $dirarray[0]
$folder2=$folder&$dirarray[$Z]&"\"
$append=$dirarray[$Z]&"\"
if fileexists($folder2&"album.m3u") then
filedelete($folder2&"album.m3u")
EndIf
if fileexists($folder2&"*.mp3") or fileexists($folder2&"*.wma") Then
If fileexists($folder2&"*.mp3") Then
$listarray2=_FileListToArray($folder2,"*.mp3")
EndIf
If fileexists($folder2&"*.wma") Then
$listarray2=_FileListToArray($folder2,"*.wma")
EndIf
For $Y=1 to $listarray2[0]
FileWriteLine($albumm3u,$append&$listarray2[$Y])
Next
If $Z=1 Then
$trackfilename=$folder
;ConsoleWrite("dirrarray: "&$trackfilename&@CR)
$file =$folder&$dirarray[$Z]&"\"&$listarray2[$Z]
; Load the tags from your specified file
ConsoleWrite("id3 file1: "&$file&@CR)
$sGenre = $oId3.Genre
If $listarray2[0]>1 Then
$file2=$folder&$dirarray[$Z+1]&"\"&$listarray2[$Z+1]
$oId3.LoadFromFile ($file2, True)
Endif
EndIf
EndIf
ElseIf fileexists($folder2&"*.flac") Then
$listarray2=_FileListToArray($folder2,"*.flac")
Next
If $Z=1 Then
$sLeadArtist = ""
$sAlbum = ""
EndIf
EndIf
Next
Endif
$folderloc=StringTrimRight($files[$x],10) ; remove folder.jpg from end of the string
if $iswebserver=true Then
$folderloc=StringTrimLeft($folderloc,$webpathlen)
endIf
filewriteline($Falbuminfo,"<albuminfo>")
filewriteline($Falbuminfo,"<artLocation>\folder.jpg</artLocation>")
filewriteline($Falbuminfo,"<genre>"&$genre&"</genre>")
filewriteline($Falbuminfo,"<artist>"&$sLeadArtist&"</artist>")
filewriteline($Falbuminfo,"<album>"&$sAlbum&"</album>")
filewriteline($Falbuminfo,"<folder>"&$folderloc&"</folder>")
filewriteline($Falbuminfo, "</albuminfo>")
Next
;Filedelete("albuminfob4.xml")
$temp=$temp&","
FileWriteline("genre.txt",$temp)
FileClose("genre.txt")
ConsoleWrite("done")
RunWait("xmlparser.exe")
SplashOff()
SplashTextOn("Message","Done. Reloading Skin.",500,50,@DesktopWidth/2-500/2,@DesktopHeight/2-50/2,1,"Arial","28","800")
Sleep(2000)
SplashOff()
SendCommand($My_Hwnd, $hwnd_RR, "RELOADSKIN")
Exit
Build-Artist.au3
Code:
#include<Array.au3>
#include<File.au3>
Dim $dir
$musicpath= InputBox("Music Folder","Path to your music folders. Put C:\MUSIC if your directory is structured in this manner:"&@CR&"C:\Music\Album1"&@CR&"C:\Music\Rock\Album2"&@CR&"Do NOT put \ at the end. Edit builder-alpha.ini if you mess up.")
EndIf
if @error then
Sleep(3000)
endif
Runwait( @comspec & " /c del artist_*.xml","",@SW_HIDE)
dim $listarray2
dim $listarray
Dim $FileCount = 0
dim $files[1000]
dim $count
dim $folder
dim $foldersplit
dim $sLeadArtist
dim $sGenre
dim $sAlbum
dim $foldercount
dim $trackfolder
dim $isflac
dim $letter
dim $xmlfile="Artist_"
dim $letters[100]
dim $lettercount=0
dim $letterindex=1
if FileExists("Artistlist.txt") then filedelete("Artistlist.txt")
For $x = 1 To $Filecount
$folder= $files[$x]&"\"
$trackfolder=$foldersplit[$foldercount-1]
$isflac=0
$trackfolderlen=StringLen($trackfolder)
FileWriteLine("Artistlist.txt",$folder)
If fileexists($folder&"album.m3u") then filedelete($folder&"album.m3u")
$isflac=1
Else
$listarray=""
endif
Next
if $isflac=0 Then
; Load the tags
;ConsoleWrite("id3file1: "&$file&@CR)
$oId3.LoadFromFile($file, True)
Endif
EndIf
Else
$sLeadArtist = ""
$sAlbum = ""
EndIf
Else
;_ArrayDisplay($dirarray)
EndIf
EndIf
EndIf
Next
If $Z=1 Then
ConsoleWrite("id3 file1: "&$file)
Endif
EndIf
EndIf
Next
If $Z=1 Then
$sLeadArtist = ""
$sAlbum = ""
EndIf
EndIf
Next
Endif
If $sLeadArtist="" Then
$letter=StringLeft($trackfolder,1)
Else
$letter=StringLeft($sLeadArtist,1)
EndIf
If $letter=" " OR $letter="(" OR $letter="[" OR $letter="*" Then
$letter=StringMid($trackfolder,2,1)
ElseIf $letter="#" OR $letter="0" OR $letter="1" OR $letter="2" OR $letter="3" OR $letter="4" OR $letter="5" OR $letter="6" OR $letter="=7" OR $letter="8" OR $letter="9" Then
$letter="#"
EndIf
$letter=StringUpper($letter)
If _ArraySearch($letters,$letter,1)==-1 Then
$letters[$lettercount]=$letter
$lettercount+=1
EndIf
If FileExists($xmlfile&$letter&".xml")=0 Then
$currentfile=FileOpen($xmlfile&$letter&".xml",33)
FileWriteLine($currentfile,'<?xml version="1.0" encoding="UTF-16"?>')
Filewriteline($currentfile,"<artworkinfo>")
Else
EndIf
ConsoleWrite($letter&" "&$folder&" "&$sLeadArtist&" "&$sAlbum&@CR)
FileWriteLine($currentfile,"<albuminfo>")
FileWriteLine($currentfile,"<artLocation>\folder.jpg</artLocation>")
FileWriteLine($currentfile,"<genre>"&$sGenre&"</genre>")
FileWriteLine($currentfile,"<artist>"&$sLeadArtist&"</artist>")
FileWriteLine($currentfile,"<album>"&$sAlbum&"</album>")
FileWriteLine($currentfile,"<folder>"&$folder&"</folder>")
FileWriteLine($currentfile, "</albuminfo>")
FileClose($currentfile)
Next
; Finalize XML files and empty array
dim $artists=""
dim $xmlfiles[200]
$filecount=0
$FILEMASK="Artist_"
$xmlfiles=_FileListToArray(@ScriptDir,"Artist*.xml",1)
FileClose("Artistlist.txt")
;_ArrayDisplay($xmlfiles)
For $I = 1 To $xmlfiles[0]
$thisfile=FileOpen($xmlfiles[$i],33)
Filewriteline($thisfile,"</artworkinfo>")
FileClose($thisfile)
Next
; Write artist.txt
If FileExists("artist.txt") ==1 Then
FileDelete("artist.txt")
EndIf
$letters[0]=$lettercount-1
;_ArrayDisplay($letters)
_ArraySort($letters,0,1,$lettercount-1)
;\_ArrayDisplay($letters)
$artists=_ArraytoString($letters,",",1,$lettercount)
FileWriteLine("artist.txt","list="&$artists)
SplashOff()
Sleep(2000)
SplashOff()
EXIT
Local $foundfile
Local $Search
Local $File
Local $FullFilePath
While 1
ExitLoop
EndIf
Else
$files[$filecount+1]=$SourceFolder
FileWriteLine("FoldersList.txt",$SourceFolder)
$FileCount += 1
endif
EndIf
WEnd
FileClose($Search)
EndFunc
xmlparser.au3
Code:
#Include<Array.au3>
#include<file.au3>
dim $foldername=@ScriptDir
dim $FILEMASK="Genre_"
Dim $FileCount = 0
dim $files[100]
dim $linecount=0
dim $letters[100]
dim $lettercount=0
dim $letterindex=1
Runwait( @comspec & " /c del Artist_*.xml","",@SW_HIDE)
;dim $nodes[500]
if FileExists("genretoartist.txt") then filedelete("genretoartist.txt")
$files[0]=$filecount
;_ArrayDisplay($files)
For $i = 1 To $filecount
dim $file
_FileReadToArray($files[$i],$file)
Consolewrite("file: " &$files[$i] &@CR)
$linecount=$file[0]
For $x=1 to $linecount
if StringInStr($file[$x],"<albuminfo>") <> 0 Then
$getloc=StringInStr($file[$x+3],"<artist>")
;ConsoleWrite("getloc: "&$file[$x+3] &@CR)
$getloc=$getloc+8
$letter=StringMid($file[$x+3],$getloc,1)
if $letter=" " Then
$letter=StringMid($file[$x+3],$getloc+1,1)
Elseif $letter=="#" OR $letter=="0" OR $letter=="1" OR $letter=="2" OR $letter=="3" OR $letter=="4" OR $letter=="5" OR $letter=="6" OR $letter=="=7" OR $letter=="8" OR $letter=="9" Then
$letter="#"
Elseif ($letter=="<") Then
$letter="~"
Else
EndIf
$lettercount+=1
EndIf
ConsoleWrite("letter: "&$letter &"/" &$file[$x+3] &@CR)
If fileexists( $xmlfile&$letter&".xml")==0 Then
;_FileCreate($xmlfile&$letter&".xml")
$currentfile=FileOpen($xmlfile&$letter&".xml",129)
FileWriteLine($currentfile,'<?xml version="1.0" encoding="UTF-8"?>')
Filewriteline($currentfile,$file[$x])
Filewriteline($currentfile,$file[$x+1])
Filewriteline($currentfile,$file[$x+2])
Filewriteline($currentfile,$file[$x+3])
Filewriteline($currentfile,$file[$x+4])
Filewriteline($currentfile,$file[$x+5])
Filewriteline($currentfile,$file[$x+6])
Else
EndIf
Endif
Next
Next
dim $artists=""
$filecount=0
$FILEMASK="artistinfo"
ScanFolder(@ScriptDir)
FileClose("genretoartist.txt")
$thisfile=FileOpen($files[$i],129)
Next
; Write artist.txt
EndIf
EXIT
Func XMLreplace($string)
$string = StringReplace($string,'&', "&")
$string = StringReplace($string,"'", "'")
$string = StringReplace($string,"’", "'")
$string = StringReplace($string,'"', """)
$string = StringReplace($string,'<', "<")
$string = StringReplace($string,'>', ">")
$string = StringReplace($string,'—', " ")
$string = StringReplace($string,'“', " ")
$string = StringReplace($string,'”', " ")
;$string = StringReplace($string,'', " ")
$string = StringReplace($string,'®', " ")
;ConsoleWrite($xmlstr&@CR)
Return $string
EndFunc
Local $Search
Local $File
Local $FullFilePath
While 1
ExitLoop
EndIf
Else
LogFile($FullFilePath)
;ConsoleWrite($FullFilePath)
EndIf
WEnd
FileClose($Search)
EndFunc
Func LogFile($FileName)
if Stringinstr($filename,$filemask) then
$files[$filecount+1]=$filename
FileOpen("xmllist.txt",32)
FileWriteLine(@ScriptDir & "\xmllist.txt",$FileName)
$FileCount += 1
endif
EndFunc
