Page 26 of 32 FirstFirst ... 1617181920212223242526272829303132 LastLast
Results 251 to 260 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #251
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Personally I think the bigger issue is the registering / re-registering of dll's when you change skins. Is it possible to standardise those "required" dll's and have them placed in the RR folder and registered only once so that all plugins can utilise the same dll ?
  2. #252
    Nov 2004
    St Louis
    Quote Originally Posted by Valheru View Post
    Agreed!
  3. #253
    moahdib's Avatar
    Jul 2000
    I don't seem to be understanding the issue.. why would changing skins require you to re-register the dll??? The registration needs to be made only once to query the first couple mp3 songs in your folder to search for artist name. Once it is registered, it shouldn't need to be done again even if you re-run the scripts.
    I forgot to mention that there are many versions of cddbcontrol.dll. I believe i am using the latest one from AOL. If you use older versions you might run into script errors. I can't make this plugin compatible with every other plugin out there that uses the same dll.. that's asking a bit too much when I have no control over what dll each plugin uses.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  4. #254
    Jul 2007
    Ireland
    It not so much about you making coverflow compatible with every other plugin out there. but rather skinners agreeing on a standard place for dll files - so that every plugin can use the same version of the dll.
    For example, if I release a skin with coverflow in it and I have the cddbcontrol.dll registered in a folder say "rr\coverflow\cddbcontrol.dll" and all is fine. Now if you release a new skin with coverflow and you happen to have the directories as "RR\Plugins\Coverflow\cddbcontrol.dll" then don't I need to re-register your version of the dll to get it to work properly with your skin ?
  5. #255
    Raw Wave
    Jun 2002
    Virginia
    Thanks for spending some more time on this, Moahdib. For what it's worth, I tried the new flash and it doesn't help with the first song or the CPU usage. Also, for some reason it always uses a white background regardless of the background chosen in coverflow.ini.
  6. #256
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Moahdib et al,
    I'm having a hell of a time with this plug... wondering if you can help. I'm using it inside the pre-release of Sonique Evolution skin. With the first beta of that skin, I had no problem building the XML files after registering the dll (I use builder-artist only), and everything worked fine. Yesterday, a new beta of the skin was released, so I downloaded that. With the new skin, I had to rebuild my coverflow library, but now it will not rebuild. It will get to the letter Z, and then crash (a Windows "Send Error Report" crash prompt comes up). I've tried it about a zillion times now with no luck. I re-registered the dll just to be sure. No luck.
    Find attached the Windows crash log. I hope there is something in it that makes sense to one of you guys?
    Thanks in advance!
    Attached Files Attached Files
  7. #257
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Nola111 View Post
    Moahdib et al,
    Thanks in advance!
    Not sure if this is it, but did you make sure to add the lines to the skin's exectbl.ini per the coverflow instructions?
  8. #258
    Jan 2007
    New Orleans, LA
    Kbreeden, thanks for the reply.
    Interestingly, no, that exact line as shown in post #1 is not in the skin's exectbl, BUT, I went back and looked at the exectbl of the 1st beta, and it wasn't in there either. And everything worked fine then.
  9. #259
    Jan 2007
    New Orleans, LA
    Nevermind, I figured it out.
    If you have more than one instance of coverflow in the Skins folder, you're hosed. I removed the old one (from Sonic's older beta), and voila, good to go.
  10. #260
    Jan 2007
    New Orleans, LA
    Moahdib,
    Now that I have coverflow working, I see what might be a bug while browsing my albums. I've downloaded your latest .swf from above, so I'm not sure if this problem existed with the previous one:
    When I'm browsing by artist, the last couple albums of any given letter are being pulled in by the ALBUM name instead of the Artist name. For example, in my "#" folder, all my numbered artists are there, but then the last album in that group is "52nd Street" by Billy Joel. That album does NOT show up in the B's. My other Billy Joel albums do though.
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
