Page 32 of 32 FirstFirst ... 2223242526272829303132
Results 311 to 317 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #311
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Ok, here's my issue (and I haven't found the solution in this thread yet):
    I am using a modified version of coverflow.skin that was uploaded earlier into this thread, and I am having issues. I am using the 3DFX v. 3. The buttons stop responding, and the Menu button doesn't bring me back to the main menu at all, or take me anywhere for that matter! Another thing I have noticed is that the skin will start playing a song in winamp and then I loose control. I am unable to start a new song, or stop the one playing from the skin.
    I am a skinner newb trying to make sense of why I can't get the coverflow skin acting right. Please help! Attached is a copy of the skin file I am using, along with a picture:
    Attached Files Attached Files
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #312
    Jul 2003
    Quote Originally Posted by kirk78h View Post
    The only difference is the genreswitch (on). If I browse by genre and select an album, I can't exit out of the coverflow screen. If I click on the button to switch to artist, it will then close. Browsing by artist is also noticably quicker.
    Kirk
    I am having the same issue, only I am browsing by artist.
    Current build! Here
  3. #313
    Jul 2003
    Can anyone help?
    Current build! Here
  4. #314
    Newbie aleshu's Avatar
    Oct 2006
    Buenos Aires, AR
    I did this script for fixing the "first song" issue, but same as kbreeden, I am not a programmer and I do not guarantee this will actually work on different systems nor take responsibility for its use.
    What it does is very simple, searchs for RoadRunner dir, reads rr.ini and takes the music path. Then it recurses directories searching for album.m3u and rewrites it. It worked perfectly for me and took not more than 1 sec on 200 albums.
    INSTALLATION: Your RR should sit in a ***\RoadRunner\ or ***\Road Runner\ folder (can be easily customized to your needs). Just copy inside a RoadRunner SUBDIR, that is, *\RoadRunner\xxx\ or *\RoadRunner\xxx\xxx\xxx - etc. I put it $SKINPATH$\coverflow and works alright.
    Hint:
    In ExecTBL.ini:
    "COVERFLOWBUILD","RUNQW;$SKINPATH$coverflow\builde r-artist.exe||RUNQW;$SKINPATH$coverflow\fixm3u.exe"
    That would do perfectly to fix your playlists.
    Good luck
  5. #315
    Jul 2007
    Thank you, aleshu. Your script is working perfectly.
  6. #316
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by qhuy View Post
    For some reason the script did not work for me. I ran the script and and nothing happened to the m3u files.
  7. #317
    Oct 2006
    Buenos Aires, AR
    Quote Originally Posted by kbreeden View Post
    Please check if you are still having the same problem. The m3u files should "look" the same but the way they are stored is different.
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
