Page 4 of 32 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #31
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    check the pic...
    i have added the changes to the exec.tbl in the skin from IDrive
    Code:
    This is my skin path:
    C:\Program Files\Road Runner\Road Runner\skins\iDrive 2.20\iDrive
    Code:
    I have registerd the dll's, and put coverflow here:
    C:\Program Files\Road Runner\Road Runner\skins\iDrive 2.20\iDrive\Coverflow
    the process runs fine, i have tried the default autoitscript from the XML folder, it launches road runner, and says it was successful, but all i get is what is in the pic?
    seems like theres a missing left button?
    cheers
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #32
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jonessc View Post
    cheers
    More than just a missing left button, no slider, no playlist buttons and no covers.
    How is your music organised?
  3. #33
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    Example
    D:\Music\The Beatles - One (2000)
    (Artist/Album/Year) make up the folder name and there all in the Music folder in that way...
    CarPuter Progress:
  4. #34
  5. #35
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    the xml folder has to be where the coverflow.swf is, and inside of the xml folder the albuminfo.xml. you might not have a xml file at all.
  6. #36
    Nov 2006
    Wales, UK
    Try my version of the XML creator, couple of posts up.
    I have and it goes to run time error 53 'file not found', and creates debug.txt
    Code:
    This is the dubug.txt
    C:\program files\road runner\skins\rr.ini
    i have also tried copying the rr.ini to the same folder just in case, but my rr.ini is in the Road Runner folder where is should be.
    Also tried running it in the road runner folder, and i get run time error 9 'subscript out of range
    Code:
    the debug.txt reads:
    rr.ini
    Any ideas?
    CarPuter Progress:
  7. #37
    Nov 2006
    Wales, UK
    Quote Originally Posted by EL CAMINO View Post
    It's all there, including the xml file.
    CarPuter Progress:
  8. #38
  9. #39
    Nov 2006
    Wales, UK
    Where have you placed the exe?
    it should be in
    .........\Road Runner\skins\<skin name>\coverflow\xml
    Code:
    C:\Program Files\Road Runner\skins\iDrive 2.20\iDrive\Coverflow
    with the following added to the exectbl.ini from the idrive folder
    Code:
    "COVERFLOW","LOAD;coverflow_browser.skin"
    "CVRFLOW_SELECT","CLEARLIST||!SELECT||AUDIO"
    could it be a flash issue?
    CarPuter Progress:
  10. #40
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you should have a folder in the coverflow one called XML, that is where you place my CoverBrowser.exe and run
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
