Page 5 of 32 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #41
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    you should have a folder in the coverflow one called XML, that is where you place my CoverBrowser.exe and run
    Tried that as well it just throws the same error message 53 'file not found' debug.txt reads:
    Code:
    C:\Program Files\Road Runner\Skins\rr.ini
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try this one.
    removed as later version further on in thread.
    (this could turn into a treasure hunt)
  3. #43
    Nov 2006
    Wales, UK
    Runtime error 9 'subscript out of range'
    Code:
    C:\Program Files\Road Runner\skins\rr.ini
    10/10/2007|12:06:34|App path =C:\Program Files\Road Runner\skins\IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|12:06:34|C:\Program Files\Road Runner\rr.ini
    Running from Coverflow\XML from the IDrive folder
    CarPuter Progress:
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, well at least we are now getting the correct location of rr.ini.
    will put some checks in to see how it's doing with reading rr.ini to get music path.
    Back in a mo.
  5. #45
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok try this one, made a couple of changes plus added a lot more markers in the debug.
    Move on it's further down.
  6. #46
    Nov 2006
    Wales, UK
    im copying it, to try now let u know shortly
    CarPuter Progress:
  7. #47
    Nov 2006
    Wales, UK
    ive made it 'prototype idrive 2.20'
    same errors tho, heres the debug
    Code:
    10/10/2007|12:06:34|App path =C:\Program Files\Road Runner\skins\Prototype IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|12:08:13|App path =C:\Program Files\Road Runner\skins\Prototype IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|12:08:13|C:\Program Files\Road Runner\rr.ini
    10/10/2007|12:13:22|App path =C:\Program Files\Road Runner\skins\Prototype IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|12:13:22|C:\Program Files\Road Runner\rr.ini
    10/10/2007|17:09:43|App path =C:\Program Files\Road Runner\skins\Prototype IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|17:09:43|C:\Program Files\Road Runner\rr.ini
    10/10/2007|17:09:43|RR.ini value voice
    10/10/2007|17:09:43|RR.ini value musicpath
    10/10/2007|17:09:43|Music path = D:\Music\
    10/10/2007|17:09:43|RR.ini value videopath
    10/10/2007|17:09:43|RR.ini value dvdpath
    10/10/2007|17:09:43|RR.ini value launchpath
    10/10/2007|17:09:43|RR.ini value winamppath
    10/10/2007|17:09:43|RR.ini value skinpath
    10/10/2007|17:09:43|RR.ini value mpcpath
    10/10/2007|17:09:43|RR.ini value screentype
    10/10/2007|17:09:43|RR.ini value videoautohide
    10/10/2007|17:09:43|RR.ini value videohidetime
    10/10/2007|17:09:43|RR.ini value hidemouse
    10/10/2007|17:09:43|RR.ini value coverfile
    10/10/2007|17:09:43|RR.ini value albumart
    10/10/2007|17:09:43|RR.ini value useid3
    10/10/2007|17:09:43|RR.ini value showid3playlist
    10/10/2007|17:09:43|RR.ini value showid3browse
    10/10/2007|17:09:43|RR.ini value gpsmode
    10/10/2007|17:09:43|RR.ini value gpsport
    10/10/2007|17:09:43|RR.ini value mapmonkeypath
    10/10/2007|17:09:43|RR.ini value gpspath
    10/10/2007|17:09:43|RR.ini value gpsname
    10/10/2007|17:09:43|RR.ini value exitmode
    10/10/2007|17:09:43|RR.ini value showicons
    10/10/2007|17:09:43|RR.ini value showextensions
    10/10/2007|17:09:43|RR.ini value titlesafter
    10/10/2007|17:09:43|RR.ini value listfollowssong
    10/10/2007|17:09:43|RR.ini value resumemusic
    10/10/2007|17:09:43|RR.ini value audiorepeat
    10/10/2007|17:09:43|RR.ini value audioshuffle
    10/10/2007|17:09:43|RR.ini value gammamode
    10/10/2007|17:09:43|RR.ini value gammapath
    10/10/2007|17:09:43|RR.ini value dateformat
    10/10/2007|17:09:43|RR.ini value timeformat
    10/10/2007|17:09:43|RR.ini value id3listformat
    10/10/2007|17:09:43|RR.ini value id3browseformat
    10/10/2007|17:09:43|RR.ini value mastervolmap
    10/10/2007|17:09:43|RR.ini value listnumbers
    10/10/2007|17:09:43|RR.ini value noformat
    10/10/2007|17:09:43|RR.ini value hidewinamp
    10/10/2007|17:09:43|RR.ini value visuname
    10/10/2007|17:09:43|RR.ini value overspeed
    10/10/2007|17:09:43|RR.ini value scrollmode
    10/10/2007|17:09:43|RR.ini value builtinvideo
    10/10/2007|17:09:43|RR.ini value disableinternat
    10/10/2007|17:09:43|RR.ini value locale
    10/10/2007|17:09:43|RR.ini value hidetaskbar
    10/10/2007|17:09:43|RR.ini value hidedesktop
    10/10/2007|17:09:43|RR.ini value radiomode
    10/10/2007|17:09:43|RR.ini value radioline
    10/10/2007|17:09:43|RR.ini value playlistpath
    10/10/2007|17:09:43|RR.ini value lazytag
    10/10/2007|17:09:43|RR.ini value allowallfreqs
    10/10/2007|17:09:43|RR.ini value browsertype
    10/10/2007|17:09:43|RR.ini value browserpath
    10/10/2007|17:09:43|RR.ini value mapvol
    10/10/2007|17:09:43|RR.ini value phocopath
    10/10/2007|17:09:43|RR.ini value phoconodesign
    10/10/2007|17:09:43|RR.ini value standardphonebook
    10/10/2007|17:09:43|RR.ini value maxcalllistentries
    10/10/2007|17:09:43|RR.ini value debugmode
    10/10/2007|17:09:43|RR.ini value hibernateaware
    10/10/2007|17:09:43|RR.ini value enableclipping
    10/10/2007|17:09:43|RR.ini value soundcard
    10/10/2007|17:09:43|RR.ini value nozoom
    10/10/2007|17:09:43|RR.ini value ipoddrive
    10/10/2007|17:09:43|RR.ini value resolution
    10/10/2007|17:09:43|RR.ini value usegestures
    10/10/2007|17:09:43|RR.ini value leavemousealone
    10/10/2007|17:09:43|RR.ini value hibernatereload
    10/10/2007|17:09:43|RR.ini value forcehibernate
    10/10/2007|17:09:43|RR.ini value closeapps
    10/10/2007|17:09:43|RR.ini value cityweather
    10/10/2007|17:09:43|RR.ini value weatherunits
    10/10/2007|17:09:43|Read Folders
    10/10/2007|17:09:44|Test routine
    CarPuter Progress:
  8. #48
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, think I know what was causing that now (that's what happens when you just throw something together )
    try this one.
    Oh delete the debug file before running.
    Move on down
  9. #49
    Nov 2006
    Wales, UK
    Code:
    10/10/2007|18:24:36|App path =C:\Program Files\Road Runner\skins\Prototype IDrive 2.20\iDrive\Coverflow\XML
    10/10/2007|18:24:36|C:\Program Files\Road Runner\rr.ini
    10/10/2007|18:24:36|Music path = D:\Music\
    10/10/2007|18:24:36|Read Folders
    10/10/2007|18:24:36|Test routine
    CarPuter Progress:
  10. #50
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
