Page 6 of 32 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 317
Thread: Browse by Cover (Coverflow) - Updated 11/8/07
  1. #51
  2. #52
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    ok it failed the 1st time, read the debug, and it flagged a folder has to many characters in the folder name by the look of it, i have deleted that folder, rerun it again, and it says 'XML Complied', and it creates loads of xml's in the folder, so it worked!
    but the screen looks the same as the 1 i posted except the only thing thats changed is is has a b c f g l button, but everything else is missing?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  3. #53
  4. #54
    Nov 2006
    Wales, UK
    Code:
    genrelist=B,C,F,G,J,K,L,M,N,R,S,T,
    Attached Files Attached Files
    CarPuter Progress:
  5. #55
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, they look OK (ie they are similar to mine)
    Where have you put the coverflow.swf and what is your F line in coverflow.skin
  6. #56
    Nov 2006
    Wales, UK
    Its here:
    Code:
    Coverflow\coverflow.swf
    F Line= (i just cut/paste your code and change the pnps for jpg like you sed:
    Code:
    f,200,42,600,516, "coverflow\coverflow.swf"
    Cheers E
    im thinking it maybe a flash issue?
    CarPuter Progress:
  7. #57
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    and the coverflow folder has an xml folder in it, and the xml files are in there?
    if so then maybe it's a flash issue, try updating it.
    otherwise I am all out of ideas.
    actually one more.
    just create a folder with on album in it point rr.ini to that and see if that works. Make sure folder has at least one MP3 and one jpg in it.
  8. #58
    Nov 2006
    Wales, UK
    Ok i redownloaded and registered the flash8.ocx, that with your program works fine!
    thanks for your help E
    Just one problem...
    It runs soooooooooooooooooooo slow
    None of the buttons do anything (even the icons on the idrive skin) while the coverflow is running, but the flash buttons still seem to work and change through the pics ok, when i double click the album art nothing happens. I have to Ctrl/Alt/Del and kill it to get out!
    I dont think this was meant to work for me
    CarPuter Progress:
  9. #59
  10. #60
    Nov 2006
    Wales, UK
    While its smooth while im going through the albums, the mouse moves ok, i just cant get out of the screen
    EDIT
    oh fu** my cpu usuage is 100%, ouch how the hell can that take more power than everything else i have my gps/winamp/road runner dont even take 50% when everything is loaded.
    CarPuter Progress:
  1. Need Help With Damaged Bumper Cover
    By Hoshwa in forum Newbie
    Last Post: 11-29-2007, 03:40 PM
  2. Tonneau Cover for my truck
    By ford master in forum Off Topic
    Last Post: 11-05-2006, 07:56 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Best way to make a 'flip up' monitor?
    By GReeToZ in forum Fabrication
    Last Post: 01-21-2005, 06:48 PM
